[DC] Determine parameter in set_input_delay?
davyzhu
Advanced Member level 1
oriental
Hi all,
When use set_input_delay/set_output_delay, how to determine the -max/-min parameter? Is it calculated by hand , calculated by tools, or give out by some standard specification?
set_input_delay -max 498  -clock EXTSCL [find port ddc_sda_i]
set_input_delay -min 0    -clock EXTSCL [find port ddc_sda_i]
set_output_delay -max 498 -clock CLK1MHZ [find port ddc_sda_o]
set_output_delay -min 0   -clock CLK1MHZ [find port ddc_sda_o]
Best regards,
Davy
General concept is to use time budgeting. 40% of clock period is used as input and output delays
    davyzhu
Hi Megastar007,
Thanks, so the delay is calculated by hand, is it right?
Best regards,
Davy
Hi ,
This should be as a part of specification .
In general if you are doing synthesis of module you do 40% of clk . But if you constrain the same at SOC you need to go through data sheet and get the same .
Thanks & Regards
yln
    davyzhu
I think we should estimate the outside environment for the chip to give the input delay value. I am right?
    davyzhu
If u synthesize modules which is nothing without outer environment, that use 40% clock period; if else, should refer datasheet of outer chip.
    davyzhu
Hi davyzhu,
It is totally dependent on the environment where your design is going to sit.
For example if your input is driven by a block/chip which is fast enough to give the output in 20% time
then your design budget is 80% of clock period.
For a block level or IP design these margins are specified by the architect whereas at chip level this
is driven by a application requirements.:|
    davyzhu
these come under timing exception !! .....
which specifies delays on various ports
    davyzhu
