Component Replacements/Substitutions
Spork
Member level 3
transistor 1402d
Hello, I am putting together a circuit and I do not have the exact model of transistor in the schematic (BC547B).
The circuit requires two of them and as most of us, I have a bunch of other transistors. I was wondering if I could just substitute them out for the ones I have. The thing I'm not sure about is how do I know what is a good substitution and what is not?
One needed (BC547B)
One's I have on hand (MPSA05, MPSA06, MPSA56, 1402D, 417-219, 2N3702, D545-D8C, D655-F, ECG382, D261-R79, 2SD261)
Circuit is below, if you need a reference for what they are used for.
h**p://www.jdm.homepage.dk/newpic.htm
Thanks,
Spork
d545+transistor
Ok, this is your sittuation... you can go to any shop that sells electronic components and buy yourself a BC547 or you could use the 2N3702. The characteristics of the 2N3702 are pretty similair to the BC547. The BC547 is probably one of the most popular transistors and you showld always have a few laying around.
Good Luck
    Spork
bc547 substitution
You can use 2N3702, but just keep it under 100MHz, PIC programmer should work. But the best is to listen to RossiRPI and buy BC547B.
    Spork
equivalent of 2n3702
The subtitute is up to your need. Just find out the real working current/voltage/power dissipation/frequency/hfe of the transistor in your circuit, so you choose the one with parameters higher than needed, and it is OK.
nguyennam
    Spork
can 2n2222 substitute bc547
I will go ahead and buy the correct part, I was just wondering how to tell.
Thank you,
Spork
choosing transistor mpsa06
Hello, after searching a lot for this part I had no luck. I then decided to find the closest part I could. Lo and behold there is a newer part made by the same manufacturers with nearly the same exact specs. The BC107B.
Is it just new version of the same transistor?
~Spork
2n3702 equivalent
Spork, I am sorry not to look at the circuit you showed at the beginning.
In this case, any low frequency small signal Si-npn transistor will work, such as BC107, you need no care about the other parameters.
nguyennam
    Spork
electronic component substitutions
nguyennam
Thank you for the responses, I have learned a lot about electronics from this board. This is just one more thing I'll know for the future.
~Spork
bc547 substitute
It is very nice to hear you say that. Your case right now is the same with mine a few years ago at my beginning of electronics, at that time, I tried to collect every document related to replacement and equivalent of semiconductor components. Once I became more skillful, I found out that most of those kinds of documents are really useless when I understand well about components and circuits, and the real component markets.
Wish you prove yourself quickly in electronics.
nguyennam
