Sine wave generator that generates various frequencies
mr_byte31
Full Member level 5
i need an IC that can generate sine wave whith different frequency range
i need it in range of mega HZ
and i can change the the frequency easily
i need it as a carrier
Re: frequency generator
Try the MAX038. It is a waves generator until 20MHz.
frequency generator
thank u very much it is really nice
but what about a range till 1Ghz :)
i searched for mac038 but i didn't find it in my country
is there any ic instead of max038
To the range about 1 GHz I don't know if there is a specific IC to do this work.
Maybe you will find a PLL ICs that can generate waves till this frequency.
ok
i need frequency till 20M
remmber that max038 isn't found in the market
use a dds chip (from analog devices), the freq is 1ghz max.
AD9833: 12.5Mhz max.
sample is free from analog.
mr_byte31 said:
ok
FUTURLEC has the MAX038
