+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 1
    Points: 3,480, Level: 13
    Join Date
    Nov 2002
    Posts
    105
    Points
    3,480
    Level
    13
    calculate cut off frequency of 2 filter
    anybody can give me an equation about how to calculate the cutoff frequency of the filter circuit.
    how to determine the value of R and C.
    I want to have the cutoff frequency of 200Mhz.
    •   Alt12th February 2007, 05:36
      advertising
  2. #2
    Points: 7,067, Level: 20
    klystron's Avatar
    Join Date
    Jul 2002
    South Africa
    Posts
    1,014
    Points
    7,067
    Level
    20
    how calculate cutoff frequencies for a circuit
    Take a look at the pi low pass filter at http://www.electronics-tutorials.com...ss-filters.htm
    •   Alt12th February 2007, 10:57
      advertising
  3. #3
    Full Member level 1
    Points: 2,510, Level: 11
    Join Date
    Jul 2006
    Newcastle, UK
    Posts
    100
    Points
    2,510
    Level
    11
    Re: how to calculate the cutoff frequency of the filter circ
    Hi Dear ilikebbs!
    Remember! To solve such problems in a exact way; you should calculate "Transfer Function" of the circuit. After that you may find the cut-off frequency(s) as below:
    Thanks!
    1 members found this post helpful.
    •   Alt12th February 2007, 13:53
      advertising
  4. #4
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    ilikebbs,
    If the filter is driven by a voltage source, then C1 is irrelevant, and the cutoff frequency is fc = 1/(2PiRC2) (if the load is an open circuit). Do you know the source impedance and load impedance? They both affect the cutoff frequency.
    Regards,
    Kral
  5. #5
    Full Member level 1
    Join Date
    Nov 2002
    Posts
    105
    Points
    3,480
    Level
    13
    thanks for your reply.
    the circuit is used for VGA interface RGB signal filter. The PP voltage is 0.7v. The impedance should be 75 ohm.
  6. #6
    Full Member level 3
    Points: 2,998, Level: 12
    Join Date
    Feb 2002
    Posts
    175
    Points
    2,998
    Level
    12
    To calculate the cut off frequency of the filter you need to define both source and load impedances
    •   Alt13th February 2007, 17:59
      advertising
  7. #7
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    ilikebbs,
    Four questions:
    Is the source resistance 75 Ohms?
    Is the load resistance 75 Ohms? If not, what is the load resistance?
    Must the filter plus load present a 75 Ohm impedance to the source?
    Must the filter plus source present a 75 Ohm impedance to the load?
    These factors all affect the design. Once these questions are answered it is possible to proceed with a design.
    Regards,
    Kral
  8. #8
    Full Member level 1
    Join Date
    Nov 2002
    Posts
    105
    Points
    3,480
    Level
    13
    Thanks Kral.
    Source resistance is 75 ohm.
    Load resistance is 75 ohm.
    The filter plus source presents 75 ohm to the load.
    The filter plus load presents 75 ohm to the source.
