+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Points: 1,086, Level: 7
    Join Date
    Feb 2007
    Posts
    Points
    1,086
    Level
    7
    How to generate sinusoidal signal in pic controller?
    hi fndz,iwant a programe for sinusoidal pulse width modulation using pic microcontroller,please any one knows post it .
    or
    if any one knows how to generate sinusoidal signal in pic controller(programe) just post it.
    •   Alt10th February 2007, 19:00
      advertising
  2. #2
    Member level 4
    Points: 1,590, Level: 9
    Join Date
    Jan 2007
    Posts
    79
    Points
    1,590
    Level
    9
    pic sine wave microcontroller
    are you using a c compiler or assembly?
    •   Alt10th February 2007, 21:44
      advertising
  3. #3
    Advanced Member level 5
    Points: 16,636, Level: 31
    Join Date
    Jul 2001
    Oberon
    Posts
    1,897
    Points
    16,636
    Level
    31
    16pic microcontrollers from microchip
    If you visit Microchip and check out the Application notes, I'm sure you will find code to do this.
    •   Alt11th February 2007, 15:16
      advertising
  4. #4
    Full Member level 5
    Points: 3,866, Level: 14
    Join Date
    Apr 2005
    Pakistan
    Posts
    283
    Points
    3,866
    Level
    14
    sinusoidal pwm using micro controller
    Hi!
    Do u want to generate sine wave?
    if the answer is yes then there are two different methods of doing it.
    one is to use a DAC (digital to analog converter)with a controller and the other one is to use PWM(pulse width modulation) with an RC filter.
    Regards.
  5. #5
    Join Date
    Feb 2007
    Posts
    Points
    1,086
    Level
    7
    Re: pic microcontroller
    hi fndz, thanx for ur replies , i am using compiler of assembly language. for that sinusoidal pulse width modulation.can u help me now how to work out.
    i am using adc.and thencomparision technique.
  6. #6
    Full Member level 2
    Points: 2,962, Level: 12
    Achievements:
    7 years registered
    Join Date
    May 2006
    Posts
    126
    Points
    2,962
    Level
    12
    yes, i have written one,
    I will send it to u as soon as i arrive home.
    •   Alt5th March 2007, 14:31
      advertising
  7. #7
    Full Member level 1
    Points: 13,041, Level: 27
    Join Date
    May 2006
    Bulgaria, Plovdiv
    Posts
    100
    Points
    13,041
    Level
    27
    i wrote a CCS C code for sine-wave stand-alone voltage mode inverter with PIC16F876,i use a PWM Module of PIC MCU's
    Circuit and C code is here:
    http://www.4shared.com/dir/2136086/3afe23e/sharing.html
