+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 4
    Points: 2,896, Level: 12
    Join Date
    May 2006
    Cairo - Egypt
    Posts
    233
    Points
    2,896
    Level
    12
    What is the difference between these two terms: "API" & "Library"?
    What is the difference between these two terminologies "API" & "Library" ?
    thanks in advance
    •   Alt10th February 2007, 16:10
      advertising
  2. #2
    Advanced Member level 1
    Points: 5,476, Level: 17
    Join Date
    Jul 2004
    Hungary
    Posts
    474
    Points
    5,476
    Level
    17
    Re: API vs Library
    Hi!
    API = "Application Program Interface"
    It is an interface to the system embedded functions, ie. to the system DLLs in a Windows.
    As a rule, an API call is a determinated function call only. Look at any API help file!
    LIBRARY = a lot of precompiled functions for a compiler, accumulated in a LIB file.
    The compiler (the linker) links (uses, adds to the final program) these functions only if needed for the program.
    zuisti
