+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Points: 1,093, Level: 7
    Join Date
    Feb 2007
    Posts
    Points
    1,093
    Level
    7
    address lines
    can anyone tell me how many address line will a 2k memory have
  2. #2
    Newbie level 5
    Points: 1,092, Level: 7
    Join Date
    Mar 2007
    Chennai
    Posts
    8
    Points
    1,092
    Level
    7
    Re: address lines
    That depends on number of data lines you have. For a single bit data line you may need 11 address lines.
    Added after 2 minutes:
    For a 8-bit system u may need 8 address lines...
    •   Alt27th March 2007, 15:26
      advertising
  3. #3
    Junior Member level 1
    Points: 1,163, Level: 7
    Join Date
    Jan 2007
    Posts
    19
    Points
    Level
    7
    Re: address lines
    i dont think the address lines depend on the data lines it is irrespective of the data line it is solely dependant on the memory size...i think for 2k size memory irrespective od the data line it takes 11lines to access the location .....
    can u pls explain how ur logic what u have posted ............
  4. #4
    Full Member level 4
    Points: 2,402, Level: 11
    Join Date
    Feb 2006
    Posts
    199
    Points
    2,402
    Level
    11
    address lines
    2K = 2048 = 2^11. You will need 11 adress lines. If you don't believe me, just look at a 2K (non-serial) memory chip. It will have 11 address lines.
  5. #5
    Join Date
    Jan 2007
    Posts
    19
    Points
    Level
    7
    Re: address lines
    ya i completely agree with u sir......its correct...
    •   Alt29th March 2007, 05:57
      advertising
  6. #6
    Full Member level 3
    Points: 3,153, Level: 13
    Achievements:
    7 years registered
    Enlightenment's Avatar
    Join Date
    Jul 2006
    3rd Rock From Sun
    Posts
    174
    Points
    3,153
    Level
    13
    address lines
    Assuming the memory is 8-bits wide, such as a 2K x 8.
    You can compute it very quickly with a calculator:
    log(2048) / log(2) = 11
    So the equation is:
    log(memory-size) / log(2)
    1 members found this post helpful.
  7. #7
    Full Member level 1
    Points: 1,748, Level: 9
    Join Date
    Jul 2007
    India
    Posts
    112
    Points
    1,748
    Level
    9
    Re: address lines
    Its 11 address lines if its going to be 8-bit wide. If its going to be 16-bits wide, it will be 10 address lines.. If 32-bit, 9 address lines.......
  8. #8
    Full Member level 5
    Points: 4,437, Level: 15
    Achievements:
    7 years registered
    Join Date
    Feb 2008
    Bangalore
    Posts
    289
    Points
    4,437
    Level
    15
    Re: address lines
    It is very simple. To represent 2 power N locations, you need N number of address lines.
    If you need more information, contact me.
    Regards,
    N.Muralidhara
    •   Alt17th March 2008, 09:35
      advertising
  9. #9
    Newbie level 1
    Points: 759, Level: 6
    Join Date
    Sep 2008
    Posts
    Points
    759
    Level
    Re: address lines
    How did you get 10 lines if it's 16-bits wide and 9 lines if it's 32-bits wide?
  10. #10
    Junior Member level 3
    Points: 880, Level: 6
    Join Date
    Nov 2008
    cochin
    Posts
    27
    Points
    880
    Level
    Re: address lines
    i think its not correct that if data line is 16 bit wide it requre only 10 address line.
    the 11 address line only indicating that we can access 2^11 locations and the data may be 8 bit or 16 whatever way arranged in that chip plz correct me if i am wrong
  11. #11
    Newbie level 1
    Points: 406, Level: 4
    Join Date
    Sep 2010
    Posts
    Points
    406
    Level
    Re: address lines
    yes sir u r write because we hv relation
    2^n=memory(byte)
    here it denotes n as address lines
