PIC 16F877 BASED DIGITAL IC TESTER
Fragrance
East Of Earth
digital ic tester
HI FRIENDS
Today i just finished this waht a good tool it is, providing facility of adding your own chip,
and lot graphical windows interface
you can found the software for this link given below
i also add the source cdoe for the pic alonge with artical
regards
Fragrance
pic ic tester
the epemag ftp ask login password for access, can you u/l also the windows sw ?
ic 16f877
Hi Koky, here is the ICtester folder from my EPE FTP backup on
06/14/2003, I hope that helps.
Tornado
ic 16f877a
Do you know what programmer I can use for reprogramming the PIC16F877 controller? Except TK3 programmer!
epe ftp
I wanted to share this one I made, what software, preferably free, do you use in drawing schematic for uploading?**broken link removed**
ictester
Hi,all
my name's Dario and I'm Italian. I recently builded the ICTESTER that's decribed in this topic, but don't works.
I used Pic 16f877A instead pic16F877-20. May be this the problem?
Tanks all
Dario
pic16f877 ic tester
darkyuver said:
Hi,all
Tanks all
Dario
Dear Friend,
must be some thing wrong with your pic programming you may have not set the fuse bit correctly any way get the new version and upgraded exe file here read the artical for proper fuse setting bits also read the fault finding text under the given link.
regards
Fragrance
    V
digital i.c. tester
darkyuver, problem is that, because EPE magazine used own Toolkit TK3 programmer
(**broken link removed**). It uses more quantity of bit configuration, it mean then PIC controller was wrong programmed.
Bit 13 CP1 - 1 Off
12 CP0 - 1 Off
11 DBG - 1 Off
10 - 1 Off
9 WRT - 1 Off
8 CPD - 1 Off
7 LVP - 0 Off
6 BOR - 0 Off
5 CP1 - 1 Off
4 CP0 - 1 Off
3 POR - 0 On (IMPORTANT)
2 WDT - 0 Off (IMPORTANT)
1 OS1 - 1 (IMPORTANT)
0 OS0 - 0 (IMPORTANT)
Need to remake software used by most programmers. Maybe anyone help our problem?
In the ftp server, the faultthing.txt file stated that the led d3 and d4...
So, are them should be light on or off before plug in the PIC?
And it states that the D4 is wrong, and correct in circuit diagram.
Is it wrong polarity at circuit board?
Hope someone to reply me question soon coz this is really an old thread..:???:
i want circuit and program in assembly language of Pic 16Fxxx based Digital Ic tester
