+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Points: 12,797, Level: 27
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,797
    Level
    27
    digital ic tester
    HI FRIENDS
    Today i just finished this waht a good tool it is, providing facility of adding your own chip,
    and lot graphical windows interface
    you can found the software for this link given below
    ftp://ftp.epemag.wimborne.co.uk/pub/PICS/ICtester/
    i also add the source cdoe for the pic alonge with artical
    regards
    Fragrance
  2. #2
    Full Member level 2
    Points: 3,234, Level: 13
    Join Date
    May 2001
    Italy
    Posts
    145
    Points
    3,234
    Level
    13
    pic ic tester
    the epemag ftp ask login password for access, can you u/l also the windows sw ?
    1 members found this post helpful.
    •   Alt14th June 2003, 08:03
      advertising
  3. #3
    Full Member level 3
    Points: 5,938, Level: 18
    Tornado's Avatar
    Join Date
    Apr 2002
    Posts
    167
    Points
    5,938
    Level
    18
    ic 16f877
    Hi Koky, here is the ICtester folder from my EPE FTP backup on
    06/14/2003, I hope that helps.
    Tornado
    •   Alt14th June 2003, 15:34
      advertising
  4. #4
    Points: 1,105, Level: 7
    Join Date
    Sep 2008
    Posts
    Points
    1,105
    Level
    7
    ic 16f877a
    Do you know what programmer I can use for reprogramming the PIC16F877 controller? Except TK3 programmer!
    •   Alt8th November 2008, 12:08
      advertising
  5. #5
    Full Member level 2
    Points: 2,030, Level: 10
    penoy_balut's Avatar
    Join Date
    Sep 2007
    Posts
    148
    Points
    2,030
    Level
    10
    epe ftp
    I wanted to share this one I made, what software, preferably free, do you use in drawing schematic for uploading?http://s144.photobucket.com/albums/r...alICTester.jpg
  6. #6
    Newbie level 1
    Points: 960, Level: 7
    Join Date
    May 2009
    Posts
    Points
    960
    Level
    7
    ictester
    Hi,all
    my name's Dario and I'm Italian. I recently builded the ICTESTER that's decribed in this topic, but don't works.
    I used Pic 16f877A instead pic16F877-20. May be this the problem?
    Tanks all
    Dario
  7. #7
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,797
    Level
    27
    pic16f877 ic tester
    Quote Originally Posted by darkyuver
    Hi,all
    Tanks all
    Dario
    Dear Friend,
    must be some thing wrong with your pic programming you may have not set the fuse bit correctly any way get the new version and upgraded exe file here read the artical for proper fuse setting bits also read the fault finding text under the given link.
    regards
    Fragrance
  8. #8
    Join Date
    Sep 2008
    Posts
    Points
    1,105
    Level
    7
    digital i.c. tester
    darkyuver, problem is that, because EPE magazine used own Toolkit TK3 programmer
    (ftp://ftp.epemag.wimborne.co.uk/pub/PICS/ToolkitTK3/). It uses more quantity of bit configuration, it mean then PIC controller was wrong programmed.
    Bit 13 CP1 - 1 Off
    12 CP0 - 1 Off
    11 DBG - 1 Off
    10 - 1 Off
    9 WRT - 1 Off
    8 CPD - 1 Off
    7 LVP - 0 Off
    6 BOR - 0 Off
    5 CP1 - 1 Off
    4 CP0 - 1 Off
    3 POR - 0 On (IMPORTANT)
    2 WDT - 0 Off (IMPORTANT)
    1 OS1 - 1 (IMPORTANT)
    0 OS0 - 0 (IMPORTANT)
    Need to remake software used by most programmers. Maybe anyone help our problem?
  9. #9
    Newbie level 1
    Points: 371, Level: 4
    Join Date
    Nov 2010
    Posts
    Points
    371
    Level
    Re: PIC 16F877 BASED DIGITAL IC TESTER
    In the ftp server, the faultthing.txt file stated that the led d3 and d4...
    So, are them should be light on or off before plug in the PIC?
    And it states that the D4 is wrong, and correct in circuit diagram.
    Is it wrong polarity at circuit board?
    Hope someone to reply me question soon coz this is really an old thread..
    •   Alt8th January 2011, 07:47
      advertising
  10. #10
    Newbie level 1
    Points: 217, Level: 2
    Join Date
    Oct 2011
    Posts
    Points
    217
    Level
    i want circuit and program in assembly language of Pic 16Fxxx based Digital Ic tester
