+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Member level 1
    Points: 2,286, Level: 11
    Join Date
    Oct 2006
    Posts
    36
    Points
    2,286
    Level
    11
    difference between frequency and bandwidth
    Hey guys does anybody knows Difference between Analog and Digital BandWidth..
    In relation with Analog and Digital circuit design...
    •   Alt5th February 2007, 19:20
      advertising
  2. #2
    Member level 4
    Points: 1,697, Level: 9
    lythanhthuan's Avatar
    Join Date
    May 2006
    M.T.A-VN
    Posts
    68
    Points
    1,697
    Level
    9
    analog and digital bandwidth
    At here there are some useful information for you :
    en.wikipedia.org/wiki/Bandwidth
    •   Alt6th February 2007, 01:41
      advertising
  3. #3
    Member level 1
    Join Date
    Oct 2006
    Posts
    36
    Points
    2,286
    Level
    11
    comparison of analog &digital bandwidth
    but it is not still clear that while designing any analog or digital ckt how it will be used???
    •   Alt6th February 2007, 06:04
      advertising
  4. #4
    Full Member level 4
    Points: 3,535, Level: 13
    raduga_in's Avatar
    Join Date
    Aug 2005
    India's Silicon Vally
    Posts
    200
    Points
    3,535
    Level
    13
    analog digital bandwidth
    In analog design the concept of bandwidth as we
    all know is related to the frequency at which the
    output will drops it's power by 1/2 the maximum.
    In digital the bandwidth is nothing but the bit rate
    possible through the channel .. it is wrong terminology
    to use but the comp science ppl can't help stealing
    analog ppl's vocab .. anyway the maximum bits
    per second is related to the analog bandwidth by
    the very famous relation given by Shanon .. i.e.
    C = BW * log_2 ( 1 + S/N)
    Where
    C = Channel capacity in Bits per secodn
    BW= Analog bw available in channel
    S/N = Signal to Noise ration
    but sill the bandwidth in Digital depends on several
    things like signal format like RZ, NRZ and Manchester etc..
  5. #5
    Junior Member level 2
    Points: 1,334, Level: 8
    Join Date
    Mar 2006
    Posts
    22
    Points
    1,334
    Level
    8
    digital vs analog bandwidth
    Analog bandwidth is the maximum sinusoidal frequency of the analog signal the circuit works with.
    But digital bandwidth of a circuit is different.
    Digital bandwidth of a circuit is is less than analog bandwidth because digital signals are made of 1 and 0 values and these are sqaure wave signals. If you plot the the frequency spectrum of the square wave the maximum frequency content in the signal is more than the frequency of the square wave.
    For example the fourier transform of a 1MHz clock signal contains harmonics at much higher frequencies. Therefore inorder to work at clock frequecny of 1MHz a circuit bandwidth has to be more than 1MHz.
    But in analog circuit if the highest frequency of the signal is 1MHZ then your circuit BW needs to be only 1MHz.
    There is a relation for the digital bandwidth of a circuit and clock frequency.
    I forget now BW = 2.85fclock i think.
    Hope this helps
