Can I use Chipscope with ISE webpack 9.1?
rsrinivas
Advanced Member level 1
bengalooru
hello all
is ISE FOUNDATION nescessary for chipscope to work
or is ISE webpack sufficient. i have 9.1i.
thanks in advance
regards
srinivas
Re: chipscope
Chipscope requires a seperate license apart from ISE. This tool is seperate from ISE.
Evaluation copy shall be available in xilinx website
chipscope
chipscope can insert ILA AND ICON cores to capture
the signals. after the cores inserted, .bit file should be regenerated and download to fpga.you see,because ISE tools is used to generate .bit file, ISE is nescessary for chipscope to work .
Re: chipscope
Hi Srinivas,
Try using Synplicity's Identify . Thru that we can debug at the source level
Re: chipscope
hi srini,
what your ise9.1i is enough for your evaluation of chipscope pro
enjoy with onchip debuging
regards
baba
chipscope
Yes, chipscope pro evaluation version
Re: chipscope
hello,
I think nobody was pretty clear regarding ur issue... Yes theres abslutely no prob if u r using ISE webpack for ChipScopePro
