What're advantage & disadvantage between Analog & Di
RatanaRETH
Member level 2
Cambodia
Hello!
What're advantage & disadvantage between transmiting signal as Analog & Digital on line and in space?
Yours sincerely,
If you use wireline, you need a wire :), but if you use a good wire, your attenuate will be smaller. You can shield the wireline, you don't able to shield the space. :)
So, less disturbance in the case of wireline.
Re: What're advantage & disadvantage between Analog &amp
Hello!
1-What're advantage & disadvantage between transmiting signal as Analog & Digital on line?
2-What're advantage & disadvantage between transmiting signal as Analog & Digital in space?
Your faithfully,
