+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Newbie level 5
    Points: 1,120, Level: 7
    Join Date
    Jan 2007
    Posts
    10
    Points
    1,120
    Level
    7
    RTOS, difference between hard and soft real time system
    What is the difference between hard and soft real time system?
    •   Alt20th January 2007, 13:52
      advertising
  2. #2
    Junior Member level 2
    Points: 1,316, Level: 8
    Join Date
    Jun 2006
    Posts
    23
    Points
    Level
    8
    Re: RTOS
    hard real time systems are systems that cant tolerate any delay
    or if delay happens the whole system will be worthless
    soft real time systems are systems that can tolerate delay
    example for hard are break systems in automotives
    examples for soft are mp3 players or mobiles
  3. #3
    Full Member level 1
    Points: 2,433, Level: 11
    Join Date
    Apr 2004
    Posts
    116
    Points
    2,433
    Level
    11
    Re: RTOS
    QNX has a very good article that explains the differences
    http://www.qnx.com/developers/articl...cle_298_1.html
    •   Alt20th January 2007, 14:55
      advertising
  4. #4
    Junior Member level 3
    Points: 1,319, Level: 8
    Join Date
    Feb 2006
    Posts
    26
    Points
    1,319
    Level
    8
    Re: RTOS
    Hard real time --> must finish the task within the restrict time
    Soft real time --> can finish the task "on time" or exceed the deadline time for a few amount of time
    Added after 45 seconds:
    •   Alt20th January 2007, 17:41
      advertising
  5. #5
    Advanced Member level 2
    Points: 6,101, Level: 18
    Join Date
    Jun 2005
    Cairo
    Posts
    678
    Points
    6,101
    Level
    18
    Re: RTOS
    Hi
    In Hard Real Time Systems the correctnes of output depends on time. not before and not after and time must be prdictable .
    In Soft real time systems if it can't meet the required time , this will affect only the quality but not the correctnes of results. off course up to limit.
    Salam
    Hossam Alzomor
    www.i-g.org
  6. #6
    Member level 4
    Points: 1,717, Level: 9
    dragonight_x's Avatar
    Join Date
    Mar 2006
    Egypt - Cairo
    Posts
    71
    Points
    1,717
    Level
    9
    Re: RTOS
    Hard real time systems are systems that can not tolerate any delay in the response ………like cars or a planes a fracture of a seconded can be the difference between life and death. Delay for hard real time systems means failure the system is worthless.
    Soft real time systems are systems that can tolerate a degree of delay …………. Like your MP3 player or your digital camera, 2 or 3 seconds delay won’t kill you. Delay for soft real time systems is a quality isuss.
  7. #7
    Full Member level 3
    Points: 3,412, Level: 13
    ivar4ever's Avatar
    Join Date
    Jun 2006
    India
    Posts
    189
    Points
    3,412
    Level
    13
  8. #8
    Member level 3
    Points: 1,675, Level: 9
    Join Date
    Oct 2004
    Posts
    65
    Points
    1,675
    Level
    9
    Re: RTOS
    check free RTOS its a simple free real time operationg system for tiny controllers and its manual explains all.
  9. #9
    Advanced Member level 3
    Points: 5,999, Level: 18
    Achievements:
    7 years registered
    Join Date
    Jun 2007
    Posts
    821
    Points
    5,999
    Level
    18
    Re: RTOS
    do check out this too:
    Micrium - Home
    •   Alt6th September 2010, 19:38
      advertising
  10. #10
    Points: 9,782, Level: 23
    Join Date
    Aug 2004
    Egypt
    Posts
    1,185
    Points
    9,782
    Level
    23
    Re: RTOS
    Check Embedded Tips from Amr Ali: RTOS.
    I made a simple introduction to RTOS course that may simplify things to you.
    Amr
