UART configuration help for PIC16F877A
sora5563
Newbie level 5
pic16f877a hyperterminal
I recently try to send data to and from PIC16F877A via uart and the result show
in the hyperterminal, but there is the problem that nothing comes out
at the hyperterminal.
here is my source code,
LIST P=16F877A
#INCLUDE <P16F877A.inc>
__CONFIG 0x3F32
SCRATCH EQU 0x20
TMP EQU 0x21
ORG 0x200
GOTO START
ORG 0x204
GOTO START
ORG 0x205
START:
; turn off the comparater for portA
BANKSEL CMCON
MOVLW 0x07
MOVWF CMCON
;turn off the voltage reference module
BANKSEL CVRCON
MOVLW 0x00
MOVWF CVRCON
CALL UART_INIT
AGAIN:
MOVLW BANNER-1
CALL WRITE
CALL UART_GETCHAR
CALL UART_PUTCHAR
GOTO AGAIN
; UART ROUTINE
UART_INIT:
BANKSEL SPBRG
MOVLW D'129' ;set baud rate 9600
MOVWF SPBRG
MOVLW 0x20 ;transmitter enabled
MOVWF TXSTA
BCF PIE1, TXIE
BCF PIE1, RCIE
BANKSEL RCSTA
MOVLW 0x90
MOVWF RCSTA
RETURN
UART_PUTCHAR:
CHARWAIT1:
BTFSS PIR1, TXIF
GOTO CHARWAIT1
MOVWF TXREG
RETURN
UART_GETCHAR:
CHARWAIT2:
BTFSS PIR1, RCIF
GOTO CHARWAIT2
MOVWF RCREG
RETURN
;TEXT FOR USER INTERFACE
BANNER:
DT "\n\rHow are you?\n\r",0h
;WRITE A STRING TO UART
WRITE:
MOVWF SCRATCH
GoWrite:
CALL PCLsub
ADDLW 0h ; IF CONTENTS IS ZERO, Z WILL BE SET
BTFSC STATUS,Z
RETURN
CALL UART_PUTCHAR
GOTO GoWrite
;PCLsub USED FOR INDIRECT ADDRESSING
PCLsub:
INCF SCRATCH,F
MOVF SCRATCH,W
MOVWF PCL
RETURN
END
Can anyone tells me what is going wrong. the baud rate is 9600 for hyperterminal.
uart pic16f877
Hi sora5563,
Best way to debug is to start with only transmission.
Just write the code for continuously transmitting a known character on
UART. You should see the character appearing on hyperterminal.
That verifies that UART is transmitting and also settings in hyperterminal are correct. Next try only reception in a similar fashion.
Later you can integrate both in order to complete your application.
Regards,
