+ Post New Thread
Results 1 to 14 of 14
  1. #1
    Points: 1,111, Level: 7
    Join Date
    Jan 2007
    Posts
    7
    Points
    1,111
    Level
    7
    temperature sensor project
    hi everyone im doing a project on atmel microcontroller.
    the AIM of the project is to sense the ambient temperature using lm35,digitize the data using adc0804 and then display the temperature on an LCD and when the temperature exceeds a certain threshold display the message and simultaneously activate a buzzer.
    components used are:
    lm35(temperature sensor)
    adc0804
    at89c51(microcontroller)
    lcd
    source code in 'c'
    if u have ANY information or data or useful links regarding this project please reply
    thanks in advance :)
  2. #2
    Full Member level 1
    Points: 2,111, Level: 10
    Join Date
    Jul 2006
    Posts
    117
    Points
    2,111
    Level
    10
    projects on lcd with temperature sensor
    For Analog to Digital Converter there are inbuilt odules for the same in many atmel microcontrollers.You can check the datasheet for that.
    tronix
    1 members found this post helpful.
  3. #3
    Full Member level 2
    Points: 2,010, Level: 10
    Join Date
    Apr 2006
    Santa Rosa, Ca.
    Posts
    120
    Points
    2,010
    Level
    10
    simple temperature sensor project
    Give this a look... I know, I know it is PIC based but it might help...
    http://www.technology.niagarac.on.ca...atureAlarm.htm
    •   Alt17th January 2007, 06:38
      advertising
  4. #4
    Full Member level 5
    Points: 3,866, Level: 14
    Join Date
    Apr 2005
    Pakistan
    Posts
    283
    Points
    3,866
    Level
    14
    temperature sensor projects components used
    Salam!
    I think that you should use PIC or AVR for this project since they have built in ADC's as compared to 8051.
    If you decide to use PIC or AVR then it is very easy to read the temperature from LM35 and display it on an LCD.
    I have got the codes for both PIC and AVR so feel free to ask for help.
    Check the availability of these controllers in ur home country since they are easily available here in Pakistan.
    ***** hafiz.
  5. #5
    Member level 4
    Points: 1,838, Level: 9
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    Cambodia
    Posts
    69
    Points
    1,838
    Level
    9
    mazidi temperature sensor
    hi
    i hope it can help u
    thank
    buntheun
  6. #6
    Newbie level 6
    Points: 1,170, Level: 7
    Join Date
    Sep 2006
    Posts
    11
    Points
    1,170
    Level
    7
    project book on temp sensor
    Quote Originally Posted by kiranmayik
    adc0804
    lcd
    source code in 'c'
    currently for adc initialize.. using keil
    // Project: Analog to Digital Converter
    #include <REG51.H>
    sbit RD1 = P3^7;
    sbit WR1 = P3^6;
    sbit INTR = P3^5;
    sbit led = P0^7;
    // Decision for Turn ON LED
    void decision (unsigned char range1)
    if (range1 > 0x40)
    led = 1;
    else
    led = 0;
    //Main Program for Reading ADC
    void main ()
    unsigned char value;
    P1 = 0xFF; // Initialize
    P0 = 0xFF;
    INTR = 1;
    RD1 = 1;
    WR1 = 0;
    while (1)
    WR1 = 0; // Start Conversion
    WR1 = 1; // Low-to-High
    while (INTR == 1);
    RD1 = 0; // Start Read Data
    value = P1; // Read Data from ADC
    RD1 = 1; // End Read Data
    P2 = value; // Display at Port 2
    decision (value); // Decision Making
    •   Alt25th January 2007, 10:17
      advertising
  7. #7
    Member level 2
    Points: 2,430, Level: 11
    Achievements:
    7 years registered
    Join Date
    Jan 2007
    Posts
    48
    Points
    2,430
    Level
    11
    atmel temperature sensor adc tos
  8. #8
    Junior Member level 1
    Points: 1,204, Level: 7
    Join Date
    Jan 2007
    Posts
    16
    Points
    1,204
    Level
    7
    project temperature sensor with display
    thanks bro
  9. #9
    Full Member level 6
    Points: 3,526, Level: 13
    Join Date
    Jan 2005
    Posts
    339
    Points
    3,526
    Level
    13
    temperature sensor project:help needed!
    see this, interfacing LM35 with ADC0804 and parallel port. Use the same code logic
    h**p://booksbybibin.14.forumer.com/viewtopic.php?t=63
    LCD With parallel port
    h**p://booksbybibin.14.forumer.com/viewtopic.php?t=60
    Bibin John
    www.bibinjohn.tk
  10. #10
    Member level 2
    Points: 1,502, Level: 8
    Join Date
    Feb 2007
    Posts
    45
    Points
    1,502
    Level
    8
    helo...please refer to this book
    The 8051 microcontroller and embedded systems : using Assembly and C / Muhammad Ali Mazidi, Janice Gillispie Mazidi, Rolin D. McKinlay
    all example program and theory about your project available in this book....
  11. #11
    Full Member level 5
    Points: 3,940, Level: 14
    Join Date
    Feb 2003
    Pakistan
    Posts
    260
    Points
    3,940
    Level
    14
    Re: temperature sensor project:help needed!
    hi
    The best solution for your problem is the Bood written by M. ali mazidi. it is the best book with alots of examples in assembly and c. there is a good topic on temperature senser using atmel 89c51 and ADC 08xxx.
    •   Alt4th February 2007, 22:16
      advertising
  12. #12
    Points: 939, Level: 6
    Join Date
    Dec 2007
    Posts
    Points
    939
    Level
    adc0804
    lcd
    source code in 'c'
  13. #13
    Newbie level 2
    Points: 892, Level: 6
    Join Date
    Dec 2007
    Posts
    Points
    892
    Level
    thanks for all informations
    Added after 48 minutes:
    thanks alot and you need a/d
  14. #14
    Full Member level 4
    Points: 3,033, Level: 12
    Join Date
    Jan 2004
    canada
    Posts
    208
    Points
    3,033
    Level
    12
    check this out, use's a pic and basic without any external ADC
    http://users.tpg.com.au/gramo/Site/lm35dz.htm
