+ Post New Thread
Results 1 to 15 of 15
  1. #1
    Newbie level 3
    Points: 1,111, Level: 7
    Join Date
    Jan 2007
    Posts
    Points
    1,111
    Level
    7
    step up dc voltage
    My knowledge of electronics doesn't go as far as that, as increasing a given DC voltage. I would much appreciate a general explanation, one that I could use generally for different desired voltages.
    Thanks much.
    Bob Haskell
  2. #2
    Full Member level 3
    Points: 3,058, Level: 13
    Join Date
    Jul 2004
    Posts
    182
    Points
    3,058
    Level
    13
    12v to 40v
    If signal => design a level shifter
    If power => dc to dc converter (boost)
  3. #3
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    how to up dc voltage
    Use the LM2577-ADJ adjustable step-up converter ..
    Here is its data sheet:
    http://www.rose-hulman.edu/~herniter...ets/LM2577.pdf
    Regards,
    IanP
    •   Alt13th January 2007, 00:10
      advertising
  4. #4
    Member level 1
    Points: 1,665, Level: 9
    Join Date
    Oct 2005
    Posts
    41
    Points
    1,665
    Level
    9
    how to step up dc voltage
    Dear:
    you an use DC -DC converter, not transformer as the dumpfrog answer you because if u apply DC vltage on transformer the output will be zero volt.
    BR
  5. #5
    Advanced Member level 1
    Points: 3,085, Level: 13
    Join Date
    Sep 2006
    Posts
    440
    Points
    3,085
    Level
    13
    lm2577 projects
    The basic principle is converting the original DC into AC, then step this AC up to the desired value by a transformer, finally rectify it to get the necessary DC voltage.
    One of the most important pros of this principle is we can use the AC with the frequency higher than the mains, upto hundreds thousand hertz, so we can use the smaller transformer, smaller filtering capacitors and inductors, thus get the smaller and lighter DC-DC converters. In the other hand, we can stabilize the output voltage easily.
    Depending the power you need, or how important your project is, so you can design by yourself the simple circuit with 2 transistors and a transformer, or use a 555 timer as astable multivibrator with the power amplifier on transistors, or design a more complicated DC boost converter, or use the dedicated ICs for this purpose such as popular MC34063 from ON semiconductor, or buy the ready-made from any professional manufacturer as Delta, Deer, ... from China.
    You will find out it is not as so complicated as you imagine at the beginning. Free and good document are everywhere on the internet and Google is our best friend.
    Goodluck
    nguyennam
    •   Alt13th January 2007, 16:16
      advertising
  6. #6
    Full Member level 2
    Points: 2,043, Level: 10
    Join Date
    Dec 2005
    Posts
    129
    Points
    2,043
    Level
    10
    step up dc voltage
    Too difficult for U. I think that you should use LT1070HV.
    Good luck for U !
    •   Alt13th January 2007, 19:08
      advertising
  7. #7
  8. #8
    Newbie level 3
    Points: 1,499, Level: 8
    Achievements:
    7 years registered
    Join Date
    Aug 2006
    Posts
    Points
    1,499
    Level
    8
    12v to 40v
    i hope tht is too easy to implement with 6v..
    now u can use a no. of diodes in series to get a higher voltage
    i hope it will help u otherwise u can mail me
    jain.mayank@gmail.com
    Added after 3 minutes:
    otherwise one book is thr..tell me ur id...actually forgot the name...i will send u name of tht book ...actually i thought u want a regulator of 40 v
    but tht book has the step ups in dc
    mail me on my gmail id
    i will reply back
  9. #9
    Newbie level 5
    Points: 1,130, Level: 7
    Join Date
    Jan 2007
    Posts
    8
    Points
    1,130
    Level
    7
    simple voltage up converter
    If your looking for a cheap way out and if your input is going to stay the same or go to 0v 2 transistors in a darlington hookup and a few resistors should do.Just do the math.
  10. #10
    Member level 1
    Points: 2,123, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jan 2007
    Posts
    33
    Points
    2,123
    Level
    10
    12v to 40v converter
    How about using a voltage tripler..google it to get the circuit
    BR
    vabzter
  11. #11
    Newbie level 3
    Points: 1,085, Level: 7
    Join Date
    Jan 2007
    Taiyuan.China
    Posts
    Points
    1,085
    Level
    7
    dc step up voltage
    i agree with nguyennam ,basic fundamental of converter DC-DC
    •   Alt19th January 2007, 03:51
      advertising
  12. #12
    Full Member level 6
    Points: 4,873, Level: 16
    Join Date
    Apr 2005
    Posts
    391
    Points
    4,873
    Level
    16
    dc dc step-up principles
    Quote Originally Posted by haskellbob
    Thanks much.
    Bob Haskell
    Your question is incomplete. Look why: the 40V side could source 7mA or 5A.
    depending of this, the circuit topology will be completely different, also the output noise, etc.
  13. #13
    Newbie level 5
    Points: 2,012, Level: 10
    Join Date
    Jul 2005
    Posts
    10
    Points
    2,012
    Level
    10
    dc voltage step up
    Thanks much.
    Bob Haskell
    See:
    http://www.edaboard.com/viewtopic.ph...916&highlight=
  14. #14
    Member level 2
    Points: 1,784, Level: 9
    Join Date
    Jan 2007
    Posts
    45
    Points
    1,784
    Level
    9
    dc voltage increasing circuit.*pdf
    dear
    here u can use lm1577 voltage step up regulator..
    The LM1577/LM2577 are monolithic integrated circuits that provide all of the power and control functions for step-up (boost), flyback, and forward converter switching regulators. The device is available in three different output voltage versions: 12V, 15V, and adjustable
  15. #15
    Points: 4,606, Level: 16
    Achievements:
    7 years registered
    Join Date
    Jan 2006
    Singapore
    Posts
    425
    Points
    4,606
    Level
    16
    converter 12v to 40v
    Some references on DC-DC step up regulator.
    http://www.siongboon.com/projects/20...-dc_converter/
