How to simulate a bidirectional port in VHDL?
alexz
Full Member level 5
UK
How can I simulate a bidir (inout) bus in VHDL?
It does not seam to be working when I simulate it normal way.
Re: Bidirectional port
What exactly is not working? You must tristate the signal when you want to read it (should work as output) by applying a 'Z' and apply what you want when is supposed to be an input. Of course, you probably have a signal to control the direction (in or out).
Bidirectional port
in your test bench file should be something like that
driver_signal <= value when < condition > else (others => 'Z');
That is just a tristate buffer isn't it?
I am using this for the OUT direction. And just reading from the bus directly for the IN direction
Bidirectional port
yes this is tri-state buffer
