+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Junior Member level 3
    Points: 1,315, Level: 8
    showntimoon's Avatar
    Join Date
    Aug 2006
    Posts
    28
    Points
    1,315
    Level
    8
    Can 8255 be connected with a 8086 microprocessor?
    can the 8255 be connected with a microprocessor 8086 or it is used only for 8088 ??
    •   Alt24th December 2006, 12:35
      advertising
  2. #2
    Banned
    Points: 5,790, Level: 18
    Join Date
    Jun 2005
    scotland uk
    Posts
    646
    Points
    5,790
    Level
    18
    Re: 8086
    you can address the 8255 with any mcu mpu or uart etc.....
    its a dumb controller for parallel data exchange
    •   Alt24th December 2006, 13:56
      advertising
  3. #3
    Full Member level 3
    Points: 3,606, Level: 14
    Join Date
    Oct 2004
    Middle of Nowhere
    Posts
    161
    Points
    3,606
    Level
    14
    Re: 8086
    For the 8086 and the 8255 you need to demultiplex the AD bus because the 8255 requires separate address lines.
    If you don't like to do it you may use peripherals designed to live with multiplexed Address and data buses. They are 8155, 8156, 8256, 8755, 8185.
    It is possible to use those peripherals directly on a multiplexed bus, though it would be more convenient to use the 8088 processor in this case, as it uses 8-bit data bus instead of 16-bit used in the 8086.
    Regards, yego
    •   Alt24th December 2006, 15:19
      advertising
  4. #4
    Full Member level 6
    Points: 4,497, Level: 15
    Join Date
    Mar 2006
    Trento, Italy
    Posts
    394
    Points
    4,497
    Level
    15
    Re: 8086
    why not but remeber that 8086 is 16 bit but 8255 is only 8 bit supported peripheral
  5. #5
    Member level 2
    Points: 1,296, Level: 8
    Join Date
    Oct 2006
    Posts
    47
    Points
    1,296
    Level
    8
    Re: 8086
    Ya u can connect
    •   Alt1st January 2007, 11:12
      advertising
  6. #6
    Advanced Member level 3
    Points: 8,325, Level: 21
    Join Date
    Nov 2006
    Posts
    982
    Points
    8,325
    Level
    21
    Re: 8086
    Yes you can but why such complicated structure you need.
    As you may know the memory map , memory – io map.
    Read more on this topic you will get some unique decoding regarding it.
