+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Points: 1,196, Level: 7
    Join Date
    Jul 2006
    Maharashtra,India
    Posts
    Points
    1,196
    Level
    7
    How to connect USB device to a PC without USB port?
    I want to use a USB device on my computer but I do not have a USB port on my computer. Is there any way to connect a USB device to a RS232 port? Can I design it myself using USB compatible microcontroller?
    •   Alt10th December 2006, 07:47
      advertising
  2. #2
    Advanced Member level 3
    Points: 10,724, Level: 24
    budhy's Avatar
    Join Date
    Oct 2006
    Indonesia
    Posts
    828
    Points
    10,724
    Level
    24
    Re: conecting USB device
    There are Addon USB Interface Card on the market
  3. #3
    Full Member level 5
    Points: 3,928, Level: 14
    asic1984's Avatar
    Join Date
    Nov 2003
    Posts
    257
    Points
    3,928
    Level
    14
    hi
    there are pci cards that provide u with usb interface
    also there is usb to rs232 converters but i think pci cards are better solutions
    •   Alt13th December 2006, 04:56
      advertising
  4. #4
    Member level 2
    Points: 1,524, Level: 8
    Join Date
    Aug 2006
    Mars
    Posts
    50
    Points
    1,524
    Level
    8
    the simplest way would be to buy a serial to usb convertor which is readily available and is also nt very expensive.. but if u want to design it on your own you use a converter chip like FT232 etc.
    Hope it helps.
    •   Alt14th December 2006, 09:35
      advertising
  5. #5
    Advanced Member level 2
    Points: 10,590, Level: 24
    M!k's Avatar
    Join Date
    Apr 2002
    Posts
    682
    Points
    10,590
    Level
    24
    Quote Originally Posted by chintan_jagani
    That means you need an USB host (not an USB device)!!!
    Quote Originally Posted by evl_inside
    No, these are USB devices (not hosts) to which a serial device can be connected. A USB device can't be connected to these converters.
    So the simplest way would be, as already proposed, to buy a USB addon card.
    Mik
  6. #6
    Full Member level 2
    Points: 2,698, Level: 12
    jakjoud's Avatar
    Join Date
    Feb 2005
    Marrakech
    Posts
    129
    Points
    2,698
    Level
    12
    The PCI cards generate a lot of adress problems at least this is my personnal experience with them. yes there is a possibility to designe a such convertisor (RS232-USB) using a microcontroler. but it's not so easy! but you can find such device already to be bought!
  7. #7
    Full Member level 1
    Points: 3,015, Level: 12
    Join Date
    Jul 2004
    Brasov, Romania
    Posts
    105
    Points
    3,015
    Level
    12
    There are lots of PCI add-on cards on the market, some of them are exhibiting problems, but most of them are working pretty well. The microcontroller solution isn't suitable at all, no need to waste your time studying how to implement a USB host, and even if you do, you'll end up having too little processing power.
  8. #8
    Newbie level 3
    Points: 1,276, Level: 8
    Join Date
    Mar 2007
    Posts
    Points
    1,276
    Level
    8
    Every solution has its advantages and disadvantages:
    A. Adding USB host-controller hardware (PCI Add-on Card) needs operating system that supports USB (eg. Windows 98 or later). Also as we know that PCI slots have a power allowance of 10 watts, so more load on the power supply and more heat will be generated inside the system.
    B. Using a converter to USB (RS-232, parallel...) isnít normally an option when the PC has the legacy interface.
    •   Alt10th March 2007, 14:20
      advertising
  9. #9
    Full Member level 5
    Points: 4,437, Level: 15
    Achievements:
    7 years registered
    Join Date
    Feb 2008
    Bangalore
    Posts
    289
    Points
    4,437
    Level
    15
    You can design a module which contains the Serial port Interface a controller and USB interface. Very low end controller can be used to convert the serial port data into USB data format and visa versa.
    If you need more details, contact me.
    Regards,
    N. Muralidhara
    CRL-BEL
