+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Member level 2
    Points: 2,390, Level: 11
    Join Date
    Dec 2002
    Posts
    50
    Points
    2,390
    Level
    11
    300 mhz bandpass filter circuit
    Hi all
    sorry about my bad english
    I want a circuit for no-pass UHF filter. for RF antenna T.V
    It must allow to pass VHF-L and VHF-H with high quality and not allow to pass UHF
    thank you for answer
    •   Alt7th December 2006, 00:29
      advertising
  2. #2
    Advanced Member level 5
    Points: 36,491, Level: 46
    flatulent's Avatar
    Join Date
    Jul 2002
    Middle Earth
    Posts
    4,629
    Points
    36,491
    Level
    46
    uhf filter
    It looks as if a low pass filter will work. You need to specify the following:
    source impedance
    load impedance
    frequency range in MHz that will be passed
    frequency range that will be attenuated
    the amount of attenuation in the attenuated frequency range.
  3. #3
    Banned
    Points: 5,790, Level: 18
    Join Date
    Jun 2005
    scotland uk
    Posts
    646
    Points
    5,790
    Level
    18
    uhf low pass filter
    use a vhf antenna
    and you wont have a problem
    as a properly designed n fed antenna will do this job for you
    as long as you use a balun or a balanced feeder
  4. #4
    Member level 2
    Join Date
    Dec 2002
    Posts
    50
    Points
    2,390
    Level
    11
    filter uhf tv design lc
    there are a hotel and they want to control the content of channel .
    there are 2 group of rooms , some rooms are allowed to watch VHF and some rooms allowed to watch VHF and UHF.
    the allowed room may be changed, one day may be 40% of rooms allowed and one day may be 80% of rooms allowed.
    hotel central ANT. for all room . ( Each room have 1 coaxial cabel)
    I want to build a circuit that :
    1- when circuit active , the user of room not able to watch UHF ( only can watch VHF)
    2- when circuit is not active , user can see VHF and UHF channels.
    thank you
  5. #5
    Points: 12,565, Level: 26
    Borber's Avatar
    Join Date
    Jan 2000
    on third flor
    Posts
    1,602
    Points
    12,565
    Level
    26
    helical resonator low pass filter
    A 5th order low pass filter will do the job but you must specify which TV or channelization standard is in use in your country to get better answer. Are S channels used in this hotel?
    •   Alt7th December 2006, 19:02
      advertising
  6. #6
    Full Member level 6
    Points: 4,873, Level: 16
    Join Date
    Apr 2005
    Posts
    391
    Points
    4,873
    Level
    16
    filtr low kill
    Quote Originally Posted by leilarazavi2000
    thank you
    You need a simple low pass filter with one or two varactor diode. When varactor capacitance is high, the filter will kill the UHF and the poor customers will not be able to see the p*orn movies...
    •   Alt7th December 2006, 19:57
      advertising
  7. #7
    Member level 2
    Join Date
    Dec 2002
    Posts
    50
    Points
    2,390
    Level
    11
    low pass filter uhf
    [/quote]
    You need a simple low pass filter with one or two varactor diode. When varactor capacitance is high, the filter will kill the UHF and the poor customers will not be able to see the p*orn movies...[/quote]
    Yes ...you right ,but this is not for p*orn movies.
    I need low pass filter to kill UHF band. <300 MHz
    who can give me the circuit for this low pass filter?
  8. #8
    Points: 8,778, Level: 22
    Join Date
    May 2002
    Posts
    1,184
    Points
    8,778
    Level
    22
    lc filtr uhf
    You can use filter solutions software to design low pass filters.(search google)
  9. #9
    Points: 25,889, Level: 39
    Join Date
    Nov 2001
    Earth
    Posts
    3,658
    Points
    25,889
    Level
    39
    uhf band filter schematics
    You should use Helical low pass filter form at that frequency that is controlled by PIN diodes from remote current..
  10. #10
    Full Member level 4
    Points: 3,032, Level: 12
    Join Date
    Nov 2004
    Posts
    194
    Points
    3,032
    Level
    12
    no-pass filter
    Quote Originally Posted by BigBoss
    May I use L C lumped circuit on pcb? Do the pcb trace affect the frequency
    response?
    •   Alt9th December 2006, 08:02
      advertising
  11. #11
    Full Member level 5
    Points: 7,164, Level: 20
    Join Date
    Apr 2001
    Posts
    276
    Points
    7,164
    Level
    20
    uhf pass filter
    @leilarazavi2000
    you can find free but still good filter design software here:
    http://tonnesoftware.com/
    Especially get friendly with Elsie, SVCfilter and Helical.
    When you have the low pass filter that blocks signals above 300MHz you can use a pin diode switch as BigBoss mentioned, see this link on pin diodes:
    http://www.microsemi.com/literature/pinhandbook.pdf
    and refer mainly to Figs 2.6 and 2.7 and of course you have combine the filters and the diodes into a common matching circuit for 75 Ohms impedance.
    If you feel like using a double amplifier optimised separately for VHF and UHF bands in an integrated circuit form with built-in switch for either band, see this link:
    http://www.vishay.com/docs/85171/85171.pdf a data sheet for Vishay's TSDF12830YS. Using this amplifier you can compensate for a bigger insertion loss due to your filters and cables.
    rgds, unkarc
  12. #12
    Join Date
    Nov 2001
    Earth
    Posts
    3,658
    Points
    25,889
    Level
    39
    low pass vhf filter
    Quote Originally Posted by hebu
    response?
    Of course you can but a filter implemented with lumped elements will have lower qualty factor than helical resonators at that frequency due to high inductance and capacitance values.But obviously, if you use high quality components ( inductors,capacitors) that will also work but it doesn't give very sharp passing slope.
    In addition to, the pcb losses can be a trouble if you use low cost pcb material like FR3 or FR2..
    In fact, there are many methods to implement this kind of filter but all depending on cost and implementation technique.
  13. #13
    Full Member level 5
    Join Date
    Apr 2001
    Posts
    276
    Points
    7,164
    Level
    20
    active inductors filter for uhf pdf
    response?
    Yes you may, if you include the surface area of pcb traces as capacitors into your filter design. Good quality double sided pcb is preferred of course, and you have to determine unit area/capacitance between the two sides of pcb. This technics is useful mainly for wideband filters.
    There is relatively strange approach for creating pcb (mainly high voltage) capacitors by placing differently sized rectangular pcb pieces onto a bigger pcb board, see an example: http://www.irational.org/sic/radio/frb-9pole-lpf.html
    Nevertheless, this approach needs some tinkering with the surface areas...
    rgds, unkarc
