+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Member level 5
    Points: 1,946, Level: 10
    Join Date
    Sep 2006
    Posts
    90
    Points
    1,946
    Level
    10
    removable disk shows empty when explored
    Hello colleagues,
    I have a problem that the usb ports of my pc can not access the removable disk ( thumb drive ). It recoganized the drive and when explore it, nothing can see and access. It is like an empty disk. My motherboard is P4 Twins- HDTV ( Asrock ).
    Please help me what to do.
    Thanks,
    •   Alt5th December 2006, 07:25
      advertising
  2. #2
    Full Member level 1
    Points: 3,159, Level: 13
    Join Date
    Sep 2003
    Chennai, India
    Posts
    109
    Points
    3,159
    Level
    13
    cannot read removable disk
    What Operating system you are Using.
    Install correct driver for your operating system.
    Check the File Format of your OS and your USB Drive.
  3. #3
    Full Member level 4
    Points: 2,631, Level: 11
    Join Date
    Mar 2006
    Republika Srpska
    Posts
    216
    Points
    2,631
    Level
    11
    cannot access removable disk drive
    Quote Originally Posted by DavidNelly
    Hello colleagues,
    Thanks,
    Probably corrupted FAT table, partition info or something like that. There are several ways to fix it (if that is the problem in the first place) depending upon OS you are using.
  4. #4
    Member level 5
    Join Date
    Sep 2006
    Posts
    90
    Points
    1,946
    Level
    10
    cant access removable disk
    Hello ,
    Thank you for your replies. My removable disk can be read in different pc.
    I can read all files from it. I can not read only in my pc. But I can see as removable drive, not volume label. Actually it has volume label.
    My os is windows xp service pack 2.
    Thanks.
    •   Alt6th December 2006, 10:49
      advertising
  5. #5
    Full Member level 4
    Join Date
    Mar 2006
    Republika Srpska
    Posts
    216
    Points
    2,631
    Level
    11
    cannot read removable disk files
    Hello ,
    Thanks.
    Tough one. :) Then you obviously have problem with your PC. But I really don't know what to suggest. If you had to install any driver to have the disk working in the first place, try uninstalling/reinstalling it. Or try system restore. Maybe someone elese can help you better with XP.
  6. #6
    Advanced Member level 3
    Points: 9,214, Level: 22
    cyberrat's Avatar
    Join Date
    Jun 2001
    In the sewers of the U.K.
    Posts
    859
    Points
    9,214
    Level
    22
    add removable disk drive in disk management
    Something to try..
    Do you have any mapped drives?
    I.E. network drives?
    If you have a network drive that is normally mapped to the next available physical drive letter any USB key plugged in will see itself as the physical drive letter even if it is already mapped and you see no files on it.
    Can you see the drive in device managment? if so try changing it's drive letter.
    Please do not PM me questions that are better asked in the PCB forum :)
  7. #7
    Newbie level 1
    Points: 1,078, Level: 7
    Join Date
    Dec 2006
    Posts
    Points
    1,078
    Level
    7
    removable disk is not access what problem
    I have exactly the same problem and i have a little more to add... my computer crashed a while go (about 3 weeks to a month) and i tried to use a usb on it for the 1st time the other day ... BUT my two hard drives in my comp USED to be connected by raid but i now have them as 2 seperate... and since then usb has not worked... the usb connects properly (shows up in device mgmt correctly) BUT when i go into disk management (control panel > admin tools > computer mgmt > disk mgmt) it does NOT automaticaly assign a drive letter and when i DO assign it onwe (G:/ for instance) its still doesnt show in my computer .... BUT once i have assigned it one (still in disk mgmt atm) and i right click on it ... if u click "Open" it will open it in an explorer frame ... (if u hit explorer an error msg appears) very very very strange ... the plot thickens... ill keep u upto date with any advancements...
    Cheers...
    •   Alt8th December 2006, 10:15
      advertising
  8. #8
    Newbie level 3
    Points: 1,073, Level: 7
    Join Date
    Jan 2007
    Posts
    Points
    1,073
    Level
    7
    shows as removable but cant access
    I have had the same thing happen at times when a corrupted driver expects to find the drive on a different USB port.
    Try booting into safe mode, and remove the corrupted device drivers from the Device Manager. then restart normally, and reinstall the device drivers.
    you should also check the drive manufacturer's website for an updated driver package.
    Out of curiosity, what is the model of the drive you are having trouble with?
    Is it U3 enabled?
  9. #9
    Member level 2
    Points: 1,712, Level: 9
    Jerry_June's Avatar
    Join Date
    Dec 2006
    Cambodia
    Posts
    43
    Points
    1,712
    Level
    9
    windows cant acces the disk thumb drive
    oh! it have many problem, mayb ur os error, ur board, n ur USB port, n ur board have dust,
    1- try to repare r setup ur window again
    2- Clean up ur mainboard by water with soap, but care fully must expose it to the wide n sun, r with the dry air untill it dry, mean no water on it. if it still have water ur boare will lose.
  10. #10
    Member level 5
    Points: 2,005, Level: 10
    Join Date
    Oct 2005
    Posts
    93
    Points
    2,005
    Level
    10
    windows 2003 cannot access removable disk
    try to add an USB hub between the pc and the disk - mostly it helps.
    press the right button for me (anyway - let me know ...)
