Alternative for MAX7450 (Video amplifier with AGC and Clamp)
kkdelabaca
Full Member level 2
max7450
I contacted with Maxim to buy the component MAX7450, but the delivery time is 23 weeks !!!!. Now I have a prototipe and I need create an other prototype. These component is an Video-Signal Conditioners with AGC and Back-Porch Clamp. Somebody know an anternative component?
The link of the component: **broken link removed**
Thanks!
Re: Alternative for MAX7450 (Video amplifier with AGC and Cl
First of all, there is no equivalent to the MAX7450 ..
If you need only a couple of samples, try to get some through the "SAMPLES" scheme ..
Also, try MAX7451 or MAX7452 .. maybe they are available ..
Otherwise - - - - -> re-design your circuit ..
Regards,
IanP
Thanks IanP,
The estimated delivery time for the samples is also 23 weeks.
I am not going to use components of Maxim. Is unacceptable to hope almost half year to mount a board. I need re-design the circuit.
I am looking for a similar component to change only small components in the prototype.
Regards!
