+ Post New Thread
Results 1 to 16 of 16
  1. #1
    Newbie level 3
    Points: 1,097, Level: 7
    Join Date
    Nov 2006
    Posts
    Points
    1,097
    Level
    7
    Why is a transistor called a current controlled device?
    Pl detail with the theory..
    •   Alt29th November 2006, 18:57
      advertising
  2. #2
    Full Member level 4
    Points: 3,535, Level: 13
    raduga_in's Avatar
    Join Date
    Aug 2005
    India's Silicon Vally
    Posts
    200
    Points
    3,535
    Level
    13
    Transistor
    Transistor .. i suppose you are referring to Bipolar Junction Transistor .. Here you know that the
    collector current is proportional to the base current
    as
    Ic = ( Beta ) Ib hence .. here Ib is the input current
    ane Ic is the output current .. so we called it a current
    controlled device.
  3. #3
    Full Member level 1
    Points: 2,116, Level: 10
    Join Date
    Aug 2004
    Posts
    96
    Points
    2,116
    Level
    10
    Transistor
    If you want learn more about this topic, you can read Boylestad, Sedra, Rashid, among others.
  4. #4
    Member level 2
    Points: 1,586, Level: 9
    Join Date
    Jul 2006
    Posts
    46
    Points
    1,586
    Level
    9
    Re: Transistor
    as
    controlled device.
    besides, if u see in active region the collector current is independent of collector voltage and only depends upon the base current. so we could say the device out put depends upon the input current ie base current
    •   Alt1st December 2006, 04:58
      advertising
  5. #5
    Full Member level 1
    Points: 2,488, Level: 11
    Achievements:
    7 years registered
    Join Date
    Sep 2006
    Posts
    102
    Points
    2,488
    Level
    11
    Re: Transistor
    hi because in transistor there are primarily 3 currents ,ie,Ib,Ic and ie=ib+ic for further refernce u can see the working and explanation of" TRANSISTOR CURRENT FLOW MECHANISM" IN ANY OF THE STANDARD book in electronics
  6. #6
    Full Member level 3
    Points: 2,998, Level: 12
    Join Date
    Feb 2002
    Posts
    175
    Points
    2,998
    Level
    12
    Re: Transistor
    A bipolar transistor is said to be current controlled because when it is biased in the active region the output (collector) current is controlled from the input (base) current.
    A bipolar trasistor is said to be in the active region when BE junction is forward biased while CB junction is reverse biased (or viceversa)
    In this situation the collector current depends mainly on base current via β (Ic=β*Ib) and only marginally (second order effect) from collector Voltage (Early effect). Also β depends on Ic.
  7. #7
    Member level 1
    Points: 1,727, Level: 9
    Join Date
    May 2004
    Posts
    41
    Points
    1,727
    Level
    9
    Re: Transistor
    It's probably best seen in a small signal model. IB can be said to control IC.
    •   Alt3rd December 2006, 13:35
      advertising
  8. #8
    Newbie level 2
    Points: 1,082, Level: 7
    Join Date
    Dec 2006
    Posts
    Points
    1,082
    Level
    7
    Re: Transistor
    the bjt transistors are best respons for u
    they have ic and ib and ie
    ic=(beta)ib
    ie=(alfa)ic
    alfa=(beta)/(beta+1)
  9. #9
    Junior Member level 1
    Points: 1,415, Level: 8
    Join Date
    Mar 2006
    Posts
    15
    Points
    1,415
    Level
    8
    Re: Transistor
    Because voltage at input Vbe(base to emmiter voltage) remains at about 0.6V and variation of current into the base contros output variations(current, voltage both).
  10. #10
    Member level 1
    Points: 1,465, Level: 8
    Join Date
    Oct 2005
    Bangalore, S.India
    Posts
    37
    Points
    1,465
    Level
    8
    Re: Transistor
    The Transistor was described as " Trans-fer of current across a re-Sistor" by its inventor.
    No matter what you do , The base bias voltage may remain same or vary slightly but the base current can be varied widely, resultingin a corresponding increase in Collector current.
    (The Base-Emitter junction(diode) has a fixed Forward V of ~0.6 to 0.65vdc. like any other pn junction)
  11. #11
    Full Member level 2
    Points: 1,685, Level: 9
    Join Date
    Jul 2006
    Posts
    121
    Points
    1,685
    Level
    9
    Transistor
    cuz the the current in the base controls the voltage at the collector
    •   Alt8th December 2006, 13:25
      advertising
  12. #12
    Full Member level 2
    Join Date
    Jul 2006
    Posts
    121
    Points
    1,685
    Level
    9
    Transistor
  13. #13
    Member level 2
    Points: 1,316, Level: 8
    zhangseong's Avatar
    Join Date
    Sep 2006
    Posts
    45
    Points
    Level
    8
    Re: Transistor
    for Mosfet,i think is because of this equation
    ID=1/2Kn'W/L(Vgs-Vth)^2
  14. #14
    Full Member level 6
    Points: 4,163, Level: 15
    Achievements:
    7 years registered
    diemilio's Avatar
    Join Date
    Sep 2006
    Framingham, MA
    Posts
    383
    Points
    4,163
    Level
    15
    Re: Transistor
    Quote Originally Posted by zhangseong
    MOSFETS are not current controlled devices. They're voltage controlled, cause ID depends on Vgs.
  15. #15
    Full Member level 3
    Points: 2,614, Level: 11
    Join Date
    Oct 2004
    Posts
    169
    Points
    2,614
    Level
    11
    Transistor
    because o/p current is contrlled by base current..............
  16. #16
    Newbie level 3
    Points: 1,288, Level: 8
    Join Date
    Dec 2005
    Posts
    Points
    Level
    8
    Re: Transistor
    I think it's too clear from previous posts. An input current, the base current in the common emmitter stage is the parameter that makes the output variable, the collector current goes up or low. So the collector current follows the variations the input (base) current dictates.
