+ Post New Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 46
  1. #1
    Points: 12,823, Level: 27
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,823
    Level
    27
    pic controlled power supply
    HI
    I have just finished the digital power supply working fine so i decided to upload the file for other friends i hope this will good tool for your bench top with complete detial of construction and pcb firmware pc software
    and schematic
    regards
    Fragrance
  2. #2
    Points: 15,991, Level: 30
    Join Date
    Mar 2002
    Posts
    1,309
    Points
    15,991
    Level
    30
    pic based power supply
    This is the Digital Benchtop Power Supply published in Elektor 11/2001, 12/2001 and 01/2002
    You can download the most up to date firmware and PC software here: http://www.haus-am-schueberg.org/Ral...esNetzteil.zip
    If you prefer the article in German language you can download it here: http://www.haus-am-schueberg.org/Ral...l/NtBauAnl.zip
    Be aware of this correction:
    November & December 2001 (000166-1/2)
    The 10-µF electrolytics in this circuit appear with different
    voltage ratings in the parts list and the schematic. The following is offered as guidance: C3, C13-17 and C20 should have a minimum working voltage of 16 volts. C19 has to be rated at 35 V or higher. As usual, higher voltage ratings are always possible.
  3. #3
    Full Member level 1
    Points: 3,231, Level: 13
    dpechman's Avatar
    Join Date
    Mar 2002
    Brazilzil
    Posts
    102
    Points
    3,231
    Level
    13
    build digital power supply
    i have also reprepared the draws and created one new mask to pcb creation.
    1 members found this post helpful.
  4. #4
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,823
    Level
    27
    pic digital power supply
    Hi freind dpechman
    thanks for your contribution but i thinks nothing new found in your design
    it is the same design which i uploaded the diffrence is only that there is no detail,
    •   Alt8th July 2003, 13:22
      advertising
  5. #5
    Member level 3
    Points: 2,816, Level: 12
    Join Date
    Aug 2001
    Posts
    55
    Points
    2,816
    Level
    12
    digital power supply project
    Look at PIC_PSU , we working on improved version with switching preregulator, PIC12F675, 10b ADC, 10b PWM and asynchronous addressed communiccation.
  6. #6
    Newbie level 5
    Points: 1,981, Level: 10
    Join Date
    Sep 2003
    Posts
    8
    Points
    1,981
    Level
    10
    pic controlled power supply v3 ve2emm
    Hello
    has someone worked on a version with a motorola hc11 cpu ???
    •   Alt18th September 2003, 20:53
      advertising
  7. #7
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,823
    Level
    27
    power supply v3 by ve2emm
    Quote Originally Posted by mk
    hi did you have code for this if so please uplaod here for all or pm if you do not want it to share in pub
  8. #8
    Full Member level 1
    Points: 3,540, Level: 13
    Join Date
    Jul 2001
    Himalayas.(mount K2)
    Posts
    97
    Points
    3,540
    Level
    13
    digital power supply pic16f84
    I am Feeling the Fragrance :)
    But Khalid 2.45 Mb is much bigger for me to downlosd could you just let me know about the Features namely:
    1) Power quality (out put mV noise ?)
    2) Mcu used .
    3) Input Output range.
    other features ? would be really helpfull to see if it suites me or not .
    Thanks
  9. #9
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,823
    Level
    27
    pic controled power supply v3
    Quote Originally Posted by Trishool
    2) Mcu used .
    Thanks
    hi
    first thanks for intrust in power supply it has been made on pic 16f84a
    with key pad to controll voltage and current
    voltage 0-25 volt linear variable fine and course from key pad
    current 0-2.5amp linear variable from key pad
    lcd displat to indivate voltage and current variations 2X16
    pc interface so it can be controll from pc also all in the above zip file you can find
    •   Alt20th September 2003, 12:07
      advertising
  10. #10
    Join Date
    Mar 2002
    Posts
    1,309
    Points
    15,991
    Level
    30
    digital power supply - pic16f877
    Quote Originally Posted by coromonadalix
    Hello
    Yes look here: www.elektroda.pl/eboard/viewtopic.php?t=11016
  11. #11
    pic based digital power supply
    PCB in cadstar
  12. #12
    Points: 1,656, Level: 9
    Join Date
    Nov 2003
    Posts
    Points
    1,656
    Level
    9
    make digital power supply
    dear Fragrance
    I want to make digital power supply but file digital power supply.rar is cannot download please upload file is one more (or sent me to email) thank you very much
    regards
    mse
    suvit_0118@yahoo.com
  13. #13
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,823
    Level
    27
    digital benchtop power supply
    Quote Originally Posted by mse
    dear Fragrance
    regards
    mse
    i have donated 20 point to you now downlaod you can get it and also donated 20 point to lzgq
  14. #14
    Full Member level 1
    Points: 2,396, Level: 11
    Join Date
    Dec 2003
    Posts
    100
    Points
    2,396
    Level
    11
    power supply pic controlled
    Hi
    I dont know nothing about PWM and why use it....
    I this elektor proyect, in the comparator section, why use PWM, what is the philosophy??
    Can you send me some tutorial about this???
    Thank you
    PD: a pretend use ADC0832 to sense voltage/current multiplexed
  15. #15
    Newbie level 1
    Points: 1,528, Level: 8
    Join Date
    Jun 2004
    Posts
    Points
    1,528
    Level
    8
    diy digital power supply
    Does anyone have the schematic and/or layout in OrCAD compatible format?
    Would save me a lot of work
  16. #16
    Advanced Member level 1
    Points: 10,571, Level: 24
    Join Date
    Dec 2001
    Posts
    414
    Points
    10,571
    Level
    24
    how to build power energimetru digital
    How use it to redesign for pluse lab power source?
  17. #17
    Full Member level 1
    Join Date
    Dec 2003
    Posts
    100
    Points
    2,396
    Level
    11
    how to set the output voltage of a picmicro
    Hello, what is the pwm frecuency???
    Thankz
  18. #18
    Full Member level 5
    Points: 3,262, Level: 13
    Join Date
    Jun 2004
    Posts
    278
    Points
    3,262
    Level
    13
    digital laboratory power suplay pic18f452
    I ever had this idea in mind. To make a digital power supply from a PIC. But never start because of some reason.
    OK now seem like someone have did it. Can someone kindly provide more information on this. What is the output voltage range & max output current.
    Thanks & best regards.
  19. #19
    Full Member level 1
    Join Date
    Dec 2003
    Posts
    100
    Points
    2,396
    Level
    11
    digital controlled power supply project
    How its work the keypad using shif register serial in/parallel out
    --I can´t understand this point...how set the binary value for pwm desired control voltaje....
    Thank you
  20. #20
    Full Member level 1
    Points: 2,287, Level: 11
    Join Date
    Dec 2001
    Posts
    96
    Points
    2,287
    Level
    11
    +pic12f675 +digital power supply
    I have always wanted a digital controlled supply, but was wondering - how do these variable switched mode supplies work - I hate bulky transformers
    Do they have a fixed voltage switched mode followed by a linear stage or is it a complete switched design?
    •   Alt19th July 2004, 08:52
      advertising
