First of all....you should read about the capacity in OFDM system......then you should read about WiMAX IEEE 802.16 standard...understand it very well.....then you can type WiMAX capacity ( of course it will depends if you using MIMO or not )....then you can change some design parameter without affect other resrtiction in the system.
