+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 26
  1. #1
    Member level 2
    Points: 2,390, Level: 11
    Join Date
    Dec 2002
    Posts
    50
    Points
    2,390
    Level
    11
    vb6 to parallel port
    Any body knows how to access parallel port in vb6 (for win98 and xp)
    tnx
  2. #2
    Junior Member level 3
    Points: 1,975, Level: 10
    Join Date
    Jul 2002
    Posts
    27
    Points
    1,975
    Level
    10
    port32.ocx xp
    In the 32 bits operating system (like NT, 2000 & XP) you cannot access directly. You need a driver. There is a generic driver called "userport" (google it). You may need also to code assembly routines for input and output ports. The userport package come with examples.
    M&Mfuria
  3. #3
    write code in vb6 for parallel ports
    look for jan axelson's parallel port complete book. or go to his site at www.lvr.com 8)
    •   Alt21st May 2003, 18:04
      advertising
  4. #4
    Newbie level 6
    Points: 2,115, Level: 10
    Join Date
    Nov 2001
    Posts
    11
    Points
    2,115
    Level
    10
    how to print com port in vb6
    Hi
    I have been using Richard Grier's OCX and it is simple and works well
    http://ourworld.compuserve.com/homep...ier/IO_OCX.htm
    Emax
  5. #5
    Member level 5
    Points: 2,785, Level: 12
    Join Date
    Jan 2003
    Posts
    84
    Points
    2,785
    Level
    12
    parallel port xp vb6
    Another way to acces the parallel port in VB6:
    Create a DLL in Visual C++ and import this DLL in your VB program
    More information about DLL's: www.boondog.com
    Look for "Visual Basic (DLL's) and PC Interfacing" under the Tutorial link.
    I know it will work under Win98 but I'm not sure if it will work under WinXP.
    Greetz Joris
  6. #6
    Full Member level 5
    Points: 3,965, Level: 14
    Join Date
    Jul 2002
    Posts
    289
    Points
    3,965
    Level
    14
    project using serial port
    single DLLs dont work with protected mode OS like NT, W2K or XP
    you must use a driver *.sys AND a DLL
    asm routines no more work with such OS, dont loose time only to have a nice Win msg about protected mode
    check http://www.driverlinx.com/Software_P...reproducts.htm
  7. #7
    Join Date
    Jul 2002
    Posts
    27
    Points
    1,975
    Level
    10
    vb6 print to parallel port
    Userport is a generic driver (.sys) that use some special undocumented function calls in windows to grant access to any port to any user. All you need is run the executable once. You need administrator rights to install.
    No especial DLL is needed. You CAN use normal assembly instructions (like in the examples), that can be inside your code in VB or in an external DLL.
    I have used it many times in NT, 2000 and XP with no problems.
    The main drawback is that you have too much power :) so you can, for example, change bits in parallel port during a print session!
  8. #8
    Advanced Member level 3
    Points: 6,852, Level: 19
    SphinX's Avatar
    Join Date
    Jan 2002
    EGYPT
    Posts
    822
    Points
    6,852
    Level
    19
    port95nt.exe conflicts
    Read EPE Mag. AUGUST 2001.
    There is a simple project for parallel interface using VB .
    PM if you don't have it.
    Bye
    •   Alt22nd May 2003, 22:41
      advertising
  9. #9
    Junior Member level 2
    Points: 1,944, Level: 10
    Join Date
    Feb 2003
    VIETNAM
    Posts
    22
    Points
    1,944
    Level
    10
    open printer port + vb 6
    To use I/O ports in Windows NT/2000/XP. Pls Visit
    www.beyondlogic.org/porttalk/porttalk.htm.
  10. #10
    Newbie level 2
    Points: 1,742, Level: 9
    Join Date
    May 2003
    Posts
    Points
    1,742
    Level
    9
    visual basic 6 ecp ocx
    HI,
    I want to develope a home automation project using serial port, if any one have material relating this, send me at
    inam_125@hotmail.com
    with thanks
    •   Alt10th July 2003, 21:46
      advertising
  11. #11
    Points: 1,662, Level: 9
    Join Date
    Dec 2003
    Posts
    Points
    1,662
    Level
    9
    parallel port+xp+visual basic+userport+port32
    You can use the "port95nt.exe". Google it.
    It is a driver that can be user under Win 95, 98, NT, 2000 and XP.
    There are examples programs in C++ and VB.
  12. #12
    Full Member level 2
    Points: 3,783, Level: 14
    Join Date
    Oct 2003
    Argentina
    Posts
    122
    Points
    3,783
    Level
    14
    open lpt port vb6
    I use a driver called WINIO. It works under windows 98 and XP
    Now I need something from you guys.
    first, I need to know at which speed the parallel port works.
    I wanted to measure that speed with visual basic (because i need to use that language and I need to use the port.) but I dont have a wait routine with resolution in time (for ex: i need to wait 50 us os .1ms)
    Do you have an open source code to do that?
  13. #13
    Full Member level 4
    Points: 4,746, Level: 16
    Join Date
    Jan 2000
    Pakistan
    Posts
    235
    Points
    4,746
    Level
    16
    send bits to parallel port
    hi,
    I think such speed with normal LPT not possible. With EPP/ECP and DMA function it may be...
  14. #14
    Full Member level 2
    Join Date
    Oct 2003
    Argentina
    Posts
    122
    Points
    3,783
    Level
    14
    access parallel port vb under windowsxp
    Thanks sadat007 !
    Ok. O would like to know how to use those modes of operation with visual basic.
    However, I would like an accurate delay routine in VB.
    Thanks !
  15. #15
    Full Member level 4
    Join Date
    Jan 2000
    Pakistan
    Posts
    235
    Points
    4,746
    Level
    16
    visual basic 6.0 parallel port ex 02
    As much I know not possible in VB... May be in VC but no experience of VC I have.
    Sorry :?
  16. #16
    Points: 1,884, Level: 10
    Join Date
    Nov 2003
    Posts
    30
    Points
    1,884
    Level
    10
    how to access lpt port in vb codings]
    Quote Originally Posted by Bukitoo
    Thanks !
    in a module write,
    Public Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
    in your form within your code
    ' Suspend  program execution for 1 second (1000 milliseconds)
     Sleep 1000
    this is the procedure in Vb to delay your program by Milliseconds,
    it is just accurate and it won't hang up machine like for loops and stuff.
    regards,
    Sherif.
    •   Alt24th December 2003, 23:12
      advertising
  17. #17
    Full Member level 2
    Join Date
    Oct 2003
    Argentina
    Posts
    122
    Points
    3,783
    Level
    14
    vb6 + read parallel port
    Thanks sherif12 !
    I red in a book that Sleep causes all the programs hang up, not oly the one who cares for me.
    Is that true ?
  18. #18
    Join Date
    Nov 2003
    Posts
    30
    Points
    1,884
    Level
    10
    lpt3 vb win95io.dll
    nope @ all,
    i tried it in many program, all what it do is hanging the procedure or function or sub it is in, differing from for loops which hang the whole machine..
    anyway, don't beleive me and try it yourself
    thanks,
    Sherif.
  19. #19
    Newbie level 3
    Points: 1,698, Level: 9
    Join Date
    Dec 2003
    Posts
    Points
    1,698
    Level
    9
    vb6 parallel port interfacing samples
    Quote Originally Posted by leilarazavi2000
    tnx
    :D
    I did a program for to send bits to a paralell port .. I you want I ll send source code... in this moment i cant because im in the work.
    Bye
    Christian
  20. #20
    Points: 1,767, Level: 9
    Join Date
    Dec 2003
    Posts
    28
    Points
    1,767
    Level
    9
    write to a port with vb 6 codes
    Try this program:
