Why PCB color is Black
vmanojnair
Newbie level 2
pcb color
Hello Friends,
I am Manoj V , working as a internet security engineer. I have a doubt regarding Printed Circuit Board.
Why All the PCB's are in Green color ?
Hope i get right answer.
Thanks
Manoj V
pcb colors
Those Green color are called soldermask.They are available in many colors including Green & black.
The purpose is to protect the Cu layer from corrosion and provide good insulation.
black solder mask
Dindeds,
Thanks for your fast reply :)
green pcb
you can also have PCB's in Black or white color. the color of the board depends on the solder mask
black soldermask
The solder mask could be yellow or red too. It depends on customer requirement.
Regards
why are pcbs green
color never affect the performance of the PCB, it may be tradition!
circuit board colors
Most importantly - solder mask (as the name suggests) prevents the solder from bridging adjacent traces and pins. Not all circuit boards have solder mask, though. Many cheap boards in the power supplied don't have it.
solder mask color
Yes, solder mask is to avoid solder paste in between pads short together when pass through wave or reflow machine. Otherwise, the pcbA may damage due to short circuit when test by jigs.
On top of the solder mask, there is normally an addition white paint called silkscreen to print on it. ( Normally, critical areas e.g ic pads region, areas may easy to find short circuit ) The purpose is to give addition protection as well as shows reference designator number, pcb information etc.
According to latest European regulation they all MUST fullfil RoHS requirement.
pcb green
vmanojnair said:
Hello Friends,
Thanks
Manoj V
If you're referring to the physical green color of the board, it indicates it is made of glass-epoxy which is naturally greenish in color. Bakelite pcb is brown and is difficult to work with in regards to cutting, or sawing it to size. Glass-epoxy boards on the other hand are easy to work with and don't break or splinter.
If you're referring to the track-coating or film, it can be either black, green, or red.
It is just the color of the photosensitive film and can be basically any color. But is usually left green, black or red.
bakelite pcb
You can have PCB's in many colors.
Thanks for all these information.
why are pcb green
But for display PCB usually better to be in black for the contrast.
pcb black solder mask
my pcb is brown
hehe
