+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 3
    Points: 2,826, Level: 12
    Join Date
    Jul 2006
    North Judson, IN USA
    Posts
    166
    Points
    2,826
    Level
    12
    i2c length
    Hello,
    I am designing a device that uses a PIC to flash goggle-mounted RGB LED's with adjustable rate and brightness. I was considering using I2C or SPI to drive the LED's from an I/O expander also mounted on the goggles. Is this a viable idea, or is there a maximum wire length for reliable operation? Thanks in advance for your help.
    •   Alt16th November 2006, 09:55
      advertising
  2. #2
    Full Member level 1
    Points: 362, Level: 4
    Join Date
    Sep 2005
    Posts
    117
    Points
    362
    Level
    i2c cable length
    hai
    i checked a lot for this
    i found from the philips this.
    the maximum cable capacitance is limited to 500pf
    a cat5 cable has the capacitance of 17pf/feet
    anyway i think it's possible to use I2C in small distance communication.
    regards
    sun
    1 members found this post helpful.
    •   Alt16th November 2006, 15:18
      advertising
  3. #3
    Full Member level 2
    Points: 2,220, Level: 10
    Achievements:
    7 years registered
    Join Date
    Sep 2006
    India
    Posts
    126
    Points
    2,220
    Level
    10
    i2c distance
    The length can be increased significantly by running at a lower clock frequency. One particular application - clocked at about 500Hz - had a bus length of about 100m (300ft).
    http://www.esacademy.com/faq/i2c/q_and_a/faq/i2cqa1.htm
    •   Alt2nd December 2006, 12:38
      advertising
  4. #4
    Member level 4
    Points: 1,899, Level: 10
    Join Date
    Jun 2005
    Posts
    71
    Points
    1,899
    Level
    10
    i2c max length
    There's a PLC maker in my country that states one of its equipment can connect to some sensors up to 1km far away using its onboard i2c channel.
    I have no idea how this can be achieved. Low frequency???
    Ric
  5. #5
    Advanced Member level 3
    Points: 8,260, Level: 21
    Join Date
    Nov 2006
    Posts
    982
    Points
    8,260
    Level
    21
    i2c maximum length
    Dependes upon noise margin of the rxd circuit .
    •   Alt3rd December 2006, 19:45
      advertising
  6. #6
    Banned
    Points: 5,790, Level: 18
    Join Date
    Jun 2005
    scotland uk
    Posts
    646
    Points
    5,790
    Level
    18
    i2c wire length
    I2c is data level
    you simply add buffers to rework the signal levels
    every so often
    or you use an amplifier and a comparitior to rework it back to real data
    when at distances ....
    i2c error checks
    so this isnt a problem
    its there or its not like digital TV
    appart from this
    copper wire is around .12R per meter for a single telephone style cable core
    so simply work it out using resistivity of the cable and its lenght
    against the driving voltage
    so you can calculate the output voltage
    against the current you need to switch your distant device
    if its less than you need simply use a cmos gate to buffer it or cmos ttl
    they are very sensative high impedance inputs
    and need micro amps to switch them
    most often pico amps
    i would use an rf pic if you have little distance to go
    or if its a vast distance use the net and a ip stack controller
  7. #7
    Advanced Member level 2
    Points: 6,101, Level: 18
    Join Date
    Jun 2005
    Cairo
    Posts
    678
    Points
    6,101
    Level
    18
    i2c maximum distance
    Hi
    It depends on your speed , supply , pull up resistors , bus & load capacitance.
    just serch the net for USB specifications
    it's a fill from philips with all the data you need
    Salam
    Hossam Alzomor
    www.i-g.org
