+ Post New Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 53
  1. #1
    Member level 3
    Points: 2,715, Level: 12
    edinburgh's Avatar
    Join Date
    Dec 2001
    City of Angels
    Posts
    62
    Points
    2,715
    Level
    12
    cannot show hidden files
    My windows xp might be infected with the virus/worms or hijacked. Problem is - I cannot retrieve any Hidden files from the windows xp folders. When I change the setting to "shown hiddenfiles and folders" from Folder Options/View menu, this setting always goes back to the previous setting "Do not show...". So hidden files are still in the black hole and none of them can see. Very secure!
    I don't want to format HD and re-install the windows from the scratch.
    Any suggestions are welcome. Thanks.
    Edin
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    cannot see hidden files
    Try this:
    Windows XP
    To enable the viewing of Hidden files follow these steps:
    Close all programs so that you are at your desktop.
    Double-click on the My Computer icon.
    Select the Tools menu and click Folder Options.
    After the new window appears select the View tab.
    Put a checkmark in the checkbox labeled Display the contents of system folders.
    Under the Hidden files and folders section select the radio button labeled Show hidden files and folders.
    Remove the checkmark from the checkbox labeled Hide file extensions for known file types.
    Remove the checkmark from the checkbox labeled Hide protected operating system files.
    Press the Apply button and then the OK button and shutdown My Computer.
    Now your computer is configured to show all hidden files.
    Regards,
    IanP
  3. #3
    Member level 5
    Points: 2,352, Level: 11
    Achievements:
    7 years registered
    Join Date
    Sep 2006
    Posts
    84
    Points
    2,352
    Level
    11
    use hijackthis to stop the program from running
    then use startuplist to see where the program is located and when does windows start it.
    go to program and press delete! :)
    hijackthis is found here:
    http://www.spywareinfo.com/~merijn/index.php
    •   Alt12th November 2006, 10:51
      advertising
  4. #4
    Points: 1,103, Level: 7
    Join Date
    Nov 2006
    Posts
    Points
    1,103
    Level
    7
    cannot view hidden files
    the best idea is to try get them in the safe mode where virus cant run
    to go to safe mode hit f8 at the startup of the computer then chose safe mode
  5. #5
    Member level 3
    Points: 2,478, Level: 11
    Join Date
    Sep 2001
    Posts
    57
    Points
    2,478
    Level
    11
    cant see hidden files
    If you remember the name of the folder its possible.
    Click start
    go for search
    search for files and folders
    all files and folders
    more dvanced options -> click on search hidden files and folders
    after getting the folder change the folder setting
  6. #6
    Newbie level 1
    Points: 890, Level: 6
    Join Date
    Dec 2007
    Posts
    Points
    890
    Level
    hidden files cannot be shown
    Hi I have the same problem like I am unable to view my hidden files.... I have followed the prcedure below, But then also I am unable to view my hidden files....Any other suggestions, Welcome...Thanks...:
    Windows XP
  7. #7
    Member level 3
    Points: 2,152, Level: 10
    snabilat's Avatar
    Join Date
    Apr 2004
    Posts
    61
    Points
    2,152
    Level
    10
    i cannot see hidden files
    Go to Start >Run>
    Type "regedit"
    Expand HKCU\Software\Microsoft\Windows\CurrentVersion\Exp lorer\Advanced\Hidden
    change the dword value to 1.
    Hope it helps.
    BTW u have been infected by a Trojan/worm.
    Try Nod32 to scan ur system.
  8. #8
    Full Member level 3
    Points: 2,547, Level: 11
    hrhgroup's Avatar
    Join Date
    Jun 2005
    Posts
    159
    Points
    2,547
    Level
    11
    cant view hidden files
    Hi
    I have fight with this virus! And I conqure.
    I have downloaded these VB Script from NET, download and double click on them, then the problem would fix, however I suggest you to install antivirus and NOD32 is the best.
    3 members found this post helpful.
  9. #9
    Banned
    Points: 5,691, Level: 17
    Join Date
    Sep 2007
    Posts
    853
    Points
    5,691
    Level
    17
    What Virus you are talking about ?
    Is it Amvo.exe ?
    If so let me know more how you fixed.
    Thanks.
  10. #10
    Full Member level 3
    hrhgroup's Avatar
    Join Date
    Jun 2005
    Posts
    159
    Points
    2,547
    Level
    11
    i cannot see my hidden files
    I do not remember the name exactly, but it hide "Folder Options" from tools menu, and then you couldnt see your hidden files, and also the virus is a hidden file, I searched the NET and find those Script, however befor I run them, I install NOD32 with latest update.
    Good luck
    •   Alt3rd January 2008, 10:00
      advertising
  11. #11
    Newbie level 1
    Points: 877, Level: 6
    Join Date
    Jan 2008
    Posts
    Points
    877
    Level
    how to retrieve hidden files
    The vbscript works :) But I think the malware is still in my pc. I'm using Nod32 eversince and it didnt find anything. Can anyone suggest a way to detect the virus.
  12. #12
    Full Member level 5
    Points: 5,001, Level: 16
    tanveerriaz's Avatar
    Join Date
    May 2001
    Pakistan
    Posts
    287
    Points
    5,001
    Level
    16
    i cant see hidden files
  13. #13
    Newbie level 6
    Points: 950, Level: 6
    Join Date
    Jan 2008
    Bangladesh
    Posts
    12
    Points
    950
    Level
    hidden file cannot be shown
    Quote Originally Posted by edinburgh
    Edin
    If you remember the name of the file, then just write the name in the address bar and you will be logged in to that hidden file.
    Though you can access your hidden file by this way, but I sujjest you to reinstall your operating system. You may have been affected by ntldr.exe. Normally this file comes with operating system in C:\ drive and not a virus. But if it goes to another drive then it does not allow user to open his hidden files form tools menu.
    To remove it from other drives,
    1. Reinstall operating system
    2. Just after installing go to tools menu and put the tic off form "do not show hidden files" tab and " hide protected operating system files" tab.
    3. Then access every drive from the address bar unless the drives will be affcted again.
    4. Delete that ntldr.exe manually from all the drives and get rid of your problem permanently.
  14. #14
    Banned
    Join Date
    Sep 2007
    Posts
    853
    Points
    5,691
    Level
    17
    cannot enable show hidden files
    Hijack it and you'll know more about the virus.
  15. #15
    Newbie level 1
    Points: 855, Level: 6
    Join Date
    Mar 2008
    Posts
    Points
    855
    Level
    cant show hidden files
    Yes it worked exapctly as you said!
    Thnx:)
    Quote Originally Posted by hrhgroup
    Hi
  16. #16
    Junior Member level 1
    Points: 955, Level: 7
    Join Date
    Feb 2008
    Posts
    18
    Points
    955
    Level
    7
    cannot display hidden files
    ther is one antivirus that can be helpful to regain ur hidden files ,sometimes ur windows may pop up, sometime yahoo mess may be hidden those things can be regained using that antivirus u can download that frm google typing "getting hidden files back"
  17. #17
    Newbie level 1
    Points: 859, Level: 6
    Join Date
    Mar 2008
    Posts
    Points
    859
    Level
    cannot view hidden files virus
    Hi
    Thanks alot. It works perfectly.
    Many thanks.
    1 members found this post helpful.
    •   Alt6th March 2008, 15:43
      advertising
  18. #18
    Newbie level 1
    Points: 838, Level: 6
    Join Date
    Apr 2008
    Posts
    Points
    838
    Level
    i cannot view hidden files
    ur vbscript regedit workd. thx once again. 1 ques though? does it really remove virus/worm from pc, is it still out ther?
  19. #19
    Full Member level 3
    hrhgroup's Avatar
    Join Date
    Jun 2005
    Posts
    159
    Points
    2,547
    Level
    11
    cannot open hidden files
    Quote Originally Posted by nishadkvp
    ur vbscript regedit worked. thx once again. 1 ques though? does it really remove virus/worm from pc, is it still out there?
    Dear nishadkvp
    It does not remove the virus from pc, it only restore windows setting, I suggest reinstalling XP and then immediately installing NOD32 v.2.5 and update everyday.
    Good luck
  20. #20
    Newbie level 2
    Points: 826, Level: 6
    Join Date
    May 2008
    Posts
    Points
    826
    Level
    hidden file cannot show
    hello im a newby here i have a problem just like that folder option show hidden file cannot use it seem when i check the show hidden file and apply it
    it revert back to do not show hidden file so how do counter this problem
    anyone can help me i cant see my hidden file for one month
