Question about NMOS capacitor
gxxg
Newbie level 3
Nmos used for capacitor,
M1: W=20u,L=5u, m=80
M2: W=20u,L=20u, m=20
The area of M1 and M2 are equal,
area M1=20*5*80=8000
area M2=20*20*20=8000
Questions are :
(1)Which one would be better for the capicitor?
(2)Capcitor M1 equals Capcitor M2?or not?why?
Thanks.
Re: About mos capacitor
If there is only a capacitor, I think both make no difference. If you want to match 2 cap with the same dimension, square structure will be better.
Considering sidewall cap M2 has bigger cap.
    gxxg
Then how to know the size of this mos capacitor?That is ,how much it will be for a 20/20,M=20 Nmos ?10p?20p?
How to calculate or simulate?
Thanks.
Questions are :
M1 is better, because the Length is smaller, so the resistance of MOS capacitor is smaller.
The effective capacitance : M1>M2, because L of M1 is smaller
I think they are same in using as capacitor by gate to drain and source
Questions are :
If we put them in parallel using the 20u side then we will have 4 times more fringing capacitance for M1 compared with M2
About mos capacitor
For MOS capacitance,does W or L make any difference???
I think the equ value has sth to do with their perimeter
M1 is better as its ESR is smaller due to shorter length
If the Q of the Capacitor is important, then you should use big W/L values to increase the Q of the Capacitor. Therefore if you need High Q Cap, you may use the first one.
Rule of thumb: At least w/l~10
you would need to define what qualities you deem important before you can decide which is 'better'. Incidentally, what is the lowercase m stand for? I design CMOS camera chips for a living and I use NMOS devices as capacitors everywhere. Our foundry state the capacitance to be a function of W and L.
