Help !! I want to interface 8051 with the 4x4 matrix keypad
sky524810
Newbie level 3
I want to ask how to write a program with assembly language to scans my keyboard and displays any character pressed by the user on the LCD.
For example, displays keys 0-9 as numbers 0-9 on the LCD while keys 10,11,12,13,14,15 are displayed as letters A,B,C,D,E and F, respectively.
I use uVision program.
Help!!
Thanks for reading my article!
Re: Help !! I want to interface 8051 with the 4x4 matrix key
Take a look at this example:
Instead of displaying the result on an LCD panel it sends it out in ASCII format through the serial port ..
Regards,
IanP
thanks for your reply
I would like to ask may I use this program directly to 8051
This code has been written for the AT89C2051 which is reduced-pin version of the 8051 microcontroller ..
It can be DIRECTLY use with any 8051-derivative ..
Just check Input/Output pin configuration/deffinition .. that's all ..
Inputs:
	ROW0             EQU          P1.0
	ROW1             EQU          P1.1
	ROW2             EQU          P1.2
	ROW3             EQU          P1.3
	CLMN0            EQU          P1.7
	CLMN1            EQU          P1.6
	CLMN2            EQU          P1.5
 	CLMN3            EQU          P1.4
Output:
		ALERT            EQU          P3.7   ;goes low when any key's pressed
Regards,
IanP
i will help u my friend read this file
