+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Member level 4
    Points: 2,452, Level: 11
    Join Date
    Jul 2005
    Indonesia
    Posts
    79
    Points
    2,452
    Level
    11
    coaxial cable impedance
    Hi all,
    I need a coaxial cable with impedance 50 Ohm. After looking at my local electronic store there is only 75 Ohm Coaxial cable. Is there any way to converting 75 Ohm Coaxial Cable into 50 Coaxial Cable ?? perhaps by adding some circuit?? Please help me. Thanks
    Regards,
    Elits
    •   Alt30th October 2006, 23:45
      advertising
  2. #2
    Advanced Member level 5
    Points: 36,491, Level: 46
    flatulent's Avatar
    Join Date
    Jul 2002
    Middle Earth
    Posts
    4,629
    Points
    36,491
    Level
    46
    50 ohm to 75 ohm converter
    A transformer, minimum loss attenuator, or LC network will work. If you do not know how to design these, you would be better off buying 50 ohm cable via the internet.
    Your application might work with 75 ohm cable.
  3. #3
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    cable impedance
    Impedance matching network usign resistors
    The matching network shown below can be used to match two unequal impedances, provided that Z1 is grater than Z2.
              ____
         ----|____|---+---------
               R1     |
       Z1            | | R2     Z2
                     |_|
    The resistor for this circuit can be calxulated using the following equations:
      R1 = Z1 - Z2*R2 / (Z2+R2)
      R2 = Z2 * sqrt(Z1) / (Z1-Z2)
    The table below will show some precalculated values for some most common interfacing situations:
      Z1      Z2      R1      R2     Attenuation
     (ohm)   (ohm)   (ohm)   (ohm)   (dB)
       75      50     42,3    82,5    5,7
      150      50      121    61,9    9,9
      300      50      274    51,1   13,4
      150      75      110     110    7,6
      300      75      243    82.5   11,4
    Regards,
    IanP
  4. #4
    Points: 32,456, Level: 44
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    75 ohm to 50 ohm balun
    A balun converts between balanced and unbalanced, hence it's name.
    •   Alt31st October 2006, 05:23
      advertising
  5. #5
    Member level 4
    Points: 1,439, Level: 8
    Join Date
    Jun 2006
    Phils
    Posts
    69
    Points
    1,439
    Level
    8
    impedance matching coax
    yeah u r right...
    •   Alt31st October 2006, 06:56
      advertising
  6. #6
    Full Member level 3
    Points: 2,753, Level: 12
    Achievements:
    7 years registered
    saubhik's Avatar
    Join Date
    Apr 2007
    India
    Posts
    162
    Points
    2,753
    Level
    12
    50 to 75 ohm converter
    You can convert the 75 Ohm coaxial cable to 50 ohm coaxial cable or vice versa by adding a Balun (Balanced Unbalanced) having impedance =sqaureroot of(75*50)
    Or in other way you can use a transformer or a parallel resistor circuit .
  7. #7
    Member level 5
    Points: 1,967, Level: 10
    Join Date
    Dec 2007
    Posts
    92
    Points
    1,967
    Level
    10
    75 ohm to 50 ohm converter
    may i know what kind of adapter to used to convert coaxial cable impedance from 50ohm to 75 ohm
  8. #8
    Advanced Member level 2
    Points: 5,970, Level: 18
    Join Date
    Nov 2004
    Tamilnadu
    Posts
    657
    Points
    5,970
    Level
    18
    50 ohm to 75 ohm balun
    balun trensfomer or quater wave tranformer transmission line can be used for impedance matching
    •   Alt27th March 2009, 03:41
      advertising
  9. #9
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    50 to 75 ohm balun
    Elits,
    As IanP stated, a simple Resistor network can be used. However, this method results in power loss. A matching transformer will provide an impedance match with (theoretically) no loss. The turns ratio will be the square root of the impedance ratio. In your case, Sqrt(75/50) = 1.224. Others have mentioned the use of a balun. This would work, but is overly complex. Since both coaxial cables are unbalanced, the balanced - unbalanced feature provides no useful function. You probably won't be able to find a commercially available balun for 75:50 conversion.
    Regards,
    Kral
  10. #10
    Junior Member level 1
    Points: 1,835, Level: 9
    Join Date
    Nov 2003
    Posts
    16
    Points
    1,835
    Level
    9
    convert 75 ohm to 50 ohm
    See if you can find a 50 ohm to 75 ohm matching transformer (I think it's quite common and avaliable in hardware stores).
    Regards
  11. #11
    Member level 4
    Points: 1,344, Level: 8
    rfndmw's Avatar
    Join Date
    Aug 2007
    Posts
    74
    Points
    1,344
    Level
    8
    75 to 50 ohm balun
    I guess a quarter wave transformer will do the job....the impedance of the tansformer line would be sqrt(75*50)
  12. #12
    Points: 2,869, Level: 12
    Join Date
    May 2002
    España
    Posts
    17
    Points
    2,869
    Level
    12
    Re: How to Converting coaxial cable Impedance from 75 to 50
    Hi:
    In TEST equipment if the outputs are set to 50ohm just put a 25 Ohm resistor in series and calculate the insertion loss. (Method recommended by Marconi Instruments)
    Regards
