8bit comparator using 2bit comparator using VHDL
fm_com_28
Full Member level 1
Fayoum, Egypt
vhdl comparator
I want to design a 2-bit comparator using VHDL that takes two unsigned std_logic_vectrors A and B and produces bits L,G,E, where
L=1 , if A<B
G=1, if A>B
E=1, if A=B
Then Using VHDL, I want to design an 8-bit comparator that uses the 2-bit .the 8bit comparator should have two 8-bit registers that load the inputs on the rising edge of the clock and one 3bit register that loads the outputs on the falling edge of the clock.
comparator vhdl
Here it goes ... Hope this helps!
library ieee;
use ieee.std_logic_1164.all;
entity comparator is
  port (
    A : in  std_logic_vector(1 downto 0);
    B : in  std_logic_vector(1 downto 0);
    L_in : in std_logic;
    G_in : in std_logic;
    E_in : in std_logic;
    L : out std_logic;
    G : out  std_logic;
    E : out  std_logic);
end comparator;
architecture behav of comparator is
begin  -- behav
  process (A, B, L_in, G_in, E_in)
  begin  -- process
    if ( (A = B) and E_in = '1') then
      E <= '1';
    else
      E <= '0';
    end if;
    if (A(1)= '1' and B(1) = '0')
      or ( (A(1) = B(1)) and (A(0)='1' and B(0)= '0'))
      or ((A = B) and G_in = '1') then
      G <= '1';
    else
      G <= '0';
    end if;
    if (A(1)='0' and B(1) ='1')
      or ((A(1) = B(1)) and A(0)='0' and B(0)= '1')
      or ((A = B) and L_in = '1') then
      L <= '1';
    else
      L <= '0';
    end if;
  end process;
end behav;
library ieee;
entity comp_8bit is
port (
    A : in  std_logic_vector(7 downto 0);
    B : in  std_logic_vector(7 downto 0);
    L : out std_logic;
    G : out  std_logic;
    E : out  std_logic);
end comp_8bit;
architecture struct of comp_8bit is
component comparator
  port (
    L : out std_logic;
    G : out  std_logic;
    E : out  std_logic);
end component;
signal E_0, E_1, E_2, L_0, L_1, L_2, G_0, G_1, G_2 : std_logic;
begin  -- struct
  u1 : comparator port map (
    A => A(1 downto 0),
    B => B(1 downto 0),
    L_in => '0',
    G_in => '0',
    E_in => '1',
    G    => G_0,
    L    => L_0,
    E    => E_0);
  u2 : comparator port map (
    A => A(3 downto 2),
    B => B(3 downto 2),
    G_in => G_0,
    L_in => L_0,
    E_in => E_0,
    G    => G_1,
    L    => L_1,
    E    => E_1);
  u3 : comparator port map (
    A => A(5 downto 4),
    B => B(5 downto 4),
    G_in => G_1,
    L_in => L_1,
    E_in => E_1,
    L    => L_2,
    E    => E_2);
  u4 : comparator port map (
    A => A(7 downto 6),
    B => B(7 downto 6),
    G_in => G_2,
    L_in => L_2,
    E_in => E_2,
    L    => L,
    G    => G,
    E    => E);
end struct;
    fm_com_28
