+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 1
    Points: 2,594, Level: 11
    Achievements:
    7 years registered
    Join Date
    Feb 2006
    Fayoum, Egypt
    Posts
    99
    Points
    2,594
    Level
    11
    vhdl comparator
    I want to design a 2-bit comparator using VHDL that takes two unsigned std_logic_vectrors A and B and produces bits L,G,E, where
    L=1 , if A<B
    G=1, if A>B
    E=1, if A=B
    Then Using VHDL, I want to design an 8-bit comparator that uses the 2-bit .the 8bit comparator should have two 8-bit registers that load the inputs on the rising edge of the clock and one 3bit register that loads the outputs on the falling edge of the clock.
    •   Alt30th October 2006, 18:49
      advertising
  2. #2
    Advanced Member level 3
    Points: 9,269, Level: 23
    Join Date
    Jul 2004
    Posts
    892
    Points
    9,269
    Level
    23
    comparator vhdl
    Here it goes ... Hope this helps!
    library ieee;
    use ieee.std_logic_1164.all;
    entity comparator is
      port (
        A : in  std_logic_vector(1 downto 0);
        B : in  std_logic_vector(1 downto 0);
        L_in : in std_logic;
        G_in : in std_logic;
        E_in : in std_logic;
        L : out std_logic;
        G : out  std_logic;
        E : out  std_logic);
    end comparator;
    architecture behav of comparator is
    begin  -- behav
      process (A, B, L_in, G_in, E_in)
      begin  -- process
        if ( (A = B) and E_in = '1') then
          E <= '1';
        else
          E <= '0';
        end if;
        if (A(1)= '1' and B(1) = '0')
          or ( (A(1) = B(1)) and (A(0)='1' and B(0)= '0'))
          or ((A = B) and G_in = '1') then
          G <= '1';
        else
          G <= '0';
        end if;
        if (A(1)='0' and B(1) ='1')
          or ((A(1) = B(1)) and A(0)='0' and B(0)= '1')
          or ((A = B) and L_in = '1') then
          L <= '1';
        else
          L <= '0';
        end if;
      end process;
    end behav;
    library ieee;
    entity comp_8bit is
    port (
        A : in  std_logic_vector(7 downto 0);
        B : in  std_logic_vector(7 downto 0);
        L : out std_logic;
        G : out  std_logic;
        E : out  std_logic);
    end comp_8bit;
    architecture struct of comp_8bit is
    component comparator
      port (
        L : out std_logic;
        G : out  std_logic;
        E : out  std_logic);
    end component;
    signal E_0, E_1, E_2, L_0, L_1, L_2, G_0, G_1, G_2 : std_logic;
    begin  -- struct
      u1 : comparator port map (
        A => A(1 downto 0),
        B => B(1 downto 0),
        L_in => '0',
        G_in => '0',
        E_in => '1',
        G    => G_0,
        L    => L_0,
        E    => E_0);
      u2 : comparator port map (
        A => A(3 downto 2),
        B => B(3 downto 2),
        G_in => G_0,
        L_in => L_0,
        E_in => E_0,
        G    => G_1,
        L    => L_1,
        E    => E_1);
      u3 : comparator port map (
        A => A(5 downto 4),
        B => B(5 downto 4),
        G_in => G_1,
        L_in => L_1,
        E_in => E_1,
        L    => L_2,
        E    => E_2);
      u4 : comparator port map (
        A => A(7 downto 6),
        B => B(7 downto 6),
        G_in => G_2,
        L_in => L_2,
        E_in => E_2,
        L    => L,
        G    => G,
        E    => E);
    end struct;
    1 members found this post helpful.
