How to make an LFSR with a loop length of 5 or 10 clock cycles?
Elephantus
Junior Member level 3
Hi.
Does anyone know the taps to make an LFSR with a loop length of 5 or 10 clock cycles?
Thanks in advance.
Re: LFSR design question
Xilnx has a application note regarding LFSRs (XAPP210). The last section has all the taps for a 3 to 168 clock cycle LFSR. See hxxp://www.xilinx.com/bvdocs/appnotes/xapp210.pdf
    Elephantus
LFSR is used in crc computation. so, i guess this should be of some use for u.
For Loop Length of 5 take 3 DFF & when value 110 cames it should be connected 2 nand gate through clear of DFF
Thanks
Anmol
just if you have the book
HDL chip design by Douglas Smith.....go through that once
there is a detailed explanation abt LFSR
good luck
