Problem of asign waveport inside the radiation enviroment
teen55
Hi all
I'm working on a simulation of moblie phone using HFSS.
It is ok for me to assign a waveport (outside the radiation environment) to feed the
coax of the antenna (antenna inside the radiation environment). The result looks fine.
However, when I tried to assign the waveport inside the radiation environment, no
result could be seen. (Both the s-parameter and far field pattern)
*the wave port assignment I used is to define an integration line from the outside
of the coax to inside.
Could you guys tell me how to define the waveport correctly inside the radiation
environment. Thank You!!
:D
Re: Problem of asign waveport inside the radiation enviromen
You can use metal (PEC) cap after the waveport to excite within the computational domain,
Rgds.
Rgds.
Thanks asdfaaa!!
But could u explain it in more detail?
