+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 2
    Points: 1,416, Level: 8
    Join Date
    Feb 2005
    Posts
    Points
    1,416
    Level
    8
    half controlled rectifier using scr
    I want to design a half controlled SCR rectifier with PIC16f877 for driving a 15kW DC motor. is it possible? what do you suggest me to do? I have problems about firing thyristor and turning them off. they are not GTOs. I found TCA785 IC for single phase half controlled rectifier control. is it a good choice? what is the other possibilities? Should I use pulse transformer or MOC3021/51? Is there a sample circuit? for 15kW dc motor,at the end of the positive cycle, does thyritor turn off by self commutation or should I use forced commutation?
    thanks...
    •   Alt13th October 2006, 22:27
      advertising
  2. #2
    Junior Member level 3
    Points: 2,208, Level: 10
    Join Date
    May 2008
    Posts
    30
    Points
    2,208
    Level
    10
    motor control rectifier scr pulse transformer
    Use step down transformer to covert 230v AC to 5V & give it to Zero crossing detector OPAMP i.t TL082P .ZCD convert AC to Square wave. Give sq. wave output of ZCD to intergrator. Compare out put of integrator with ref. volt which give the pulse. And the pulse with the timer out put & give it to opto isolator & give out put of opto isolator to Gate Cathode of thyristor.
    Added after 3 minutes:
    also fo 15kw dc motor select the hald controlled rectifier having current capacity more than 80A.
    semikton , thosiba are the supplier of the such power thyristor & IGBT
  3. #3
    Super Moderator
    Points: 239,549, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,549
    Level
    100
    4251 rectifier
    Usual opto-tricas (e. g. MOC302x) are more sensitive to voltage transients than thyristors, so it would considerably degrade the circuit performance. Pulse transformers are the traditional solution.
    Depending on the motor type a series inductance may be required to limit the rate of current increase to a bearable value, e. g. to meet the thyristor specification.
    •   Alt16th May 2008, 08:37
      advertising
  4. #4
    Join Date
    May 2008
    Posts
    30
    Points
    2,208
    Level
    10
    control scr rectifier circuit
    we have used IL4218 for the thyristor firing .find the attached datasheet.
  5. #5
    Join Date
    May 2008
    Posts
    30
    Points
    2,208
    Level
    10
    half controlled scr
    pulse out - IL4218 led - isolated DIAC - output Gate-kathode thyristor 1 (positive cycle
    pulse out - IL4218 led - isolated DIAC - output Gate-kathode thyristor 2(negative cycle
    •   Alt16th May 2008, 09:21
      advertising
  6. #6
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,549
    Level
    100
    scr rectifier
    The IL4218 should be suitable for thyristor control. I would use a snubber anyway, as suggested in the datasheet. Also, the optotriac output should have a series diode to prevent from triggering with negative thyristor input voltage, otherwise the circuit could be destroyed. umery2k75 recently demonstrated how to with a moc3020 and a thyristor.
  7. #7
    Newbie level 1
    Points: 419, Level: 4
    Join Date
    Aug 2010
    mumabi
    Posts
    Points
    419
    Level
    I have used application control circuit for TCA785.
    the symitrical type schema used in our application.
    can you plaese give the half controlled rectifier schematic for tca785?
    1 members found this post helpful.
  8. #8
    Newbie level 3
    Points: 486, Level: 4
    Join Date
    Apr 2010
    indonesia
    Posts
    Points
    486
    Level
    Re: half controlled SCR rectifier
    in which condition that we choose pulse transformer or opto-triacs for triggering?
