+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Full Member level 1
    Points: 2,594, Level: 11
    Achievements:
    7 years registered
    Join Date
    Feb 2006
    Fayoum, Egypt
    Posts
    99
    Points
    2,594
    Level
    11
    74xx00 flip flop
    Dear,
    I want to Design a sequential circuit with two D flip-flops A and B, and one input x. When x=0, he sate of the circuit remains the same. When x=1, the circuit goes through the start transitions from 00 to 101 to 11 to 10 back to 00, and repeats.
    •   Alt3rd October 2006, 15:38
      advertising
  2. #2
    Full Member level 1
    Points: 2,111, Level: 10
    Join Date
    Jul 2006
    Posts
    117
    Points
    2,111
    Level
    10
    sequential circuit having two d flip flops
    I suggest you to consult the book
    'Digital Logic and Computer Design' by Morris Mano.
    or 'Digital Design' by the same author.
    These should be available in the e-book section of the forum.
    Regards
    tronix
  3. #3
    Advanced Member level 3
    Points: 7,169, Level: 20
    Join Date
    Jan 2006
    Bangalore India
    Posts
    805
    Points
    7,169
    Level
    20
    Blog Entries
    gray code using d flip flop
    i am not able to understand your transistions.
    please make it more clear
    "transitions from 00 to 101 to 11 to 10 back to 00, and repeats"
    what is 101 doing in two bit sequential ckt.
    i think u want 00,10,11,10,00
    is this right sequence....
    Bangalore
    9986111439 {sms only}
    EMAIL REMOVED - READ THE FORUM RULES
    •   Alt6th October 2006, 06:30
      advertising
  4. #4
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Feb 2006
    Fayoum, Egypt
    Posts
    99
    Points
    2,594
    Level
    11
    design of sequential circuit using d flip flop
    Dear,
    I want to Design a sequential circuit with two D flip-flops A and B, and one input x. When x=0, he sate of the circuit remains the same. When x=1, the circuit goes through the start transitions from 00 to 01 to 11 to 10 back to 00, and repeats.
    This is the true one
  5. #5
    Full Member level 5
    Points: 3,553, Level: 14
    lambtron's Avatar
    Join Date
    Nov 2005
    Portland, OR
    Posts
    251
    Points
    3,553
    Level
    14
    design of seqentional circuit using d flip flop
    Simple. Here's the next-state equations for AB:
    A = ( A and not X ) or ( B and X )
    B = ( B and not X ) or ( X and not A )
    •   Alt6th October 2006, 15:50
      advertising
  6. #6
    Full Member level 4
    Points: 4,144, Level: 15
    Join Date
    Nov 2004
    USA
    Posts
    211
    Points
    4,144
    Level
    15
    design d flip flop using sequential circuit
    A simple challenge (just for fun):
    Implement the circuit (described above) with standard logic chips (no PLD or uP). I'll donate 20 points to the person using the fewest chips who submits a working schematic to this topic. Assume a clock signal is available.
    -jonathan
  7. #7
    Full Member level 2
    Points: 5,998, Level: 18
    dindeds's Avatar
    Join Date
    Aug 2006
    Posts
    135
    Points
    5,998
    Level
    18
    flip flop ckt
    Nah.. you can't do that with 2 D-Flip flop without help of several others logic gates in between them.
    But then I'd rather get my 12F675 to do it in a jiffy at a fraction of the cost!
  8. #8
    Join Date
    Jan 2006
    Bangalore India
    Posts
    805
    Points
    7,169
    Level
    20
    Blog Entries
    using d flip flop make jk flip flop
    i think this can be done by JK flip flop.
    Added after 1 minutes:
    using jk will simplfy the task
    I will also try with D flip flop
    Bangalore
    •   Alt12th October 2006, 08:36
      advertising
  9. #9
    Full Member level 4
    Join Date
    Nov 2004
    USA
    Posts
    211
    Points
    4,144
    Level
    15
    circuit using flipflop
    dindreds,
    I don't understand your "fraction of the costs". I do not think you are talking about money. The 12F675 is 1.70 or so.
    The cost of a discrete logic chip is 0.25 to 0.40. I'll even add 0.15 per chip for the additional PCB space for say 0.55 per chip.
    Someone can easily (using a trick or two) implement this with three chips (2 NANDS, 74XX00, and a Dual D flip flop, 74XX74). I'm sure there are some cool implementations with JK flip flops as well. Anyway, a three chip implementation costs 1.65 at the most.
    Others may realize that this circuit is fairly simple and the logic is built (but maybe hidden) into other discrete chips. Multiplexers are good ways to implement logic for 1 to 3 variables (and some even have flip flops built into the outputs -- hmm, state machine on a chip?).
    Still others may be able to do creative, out of the box, things with counters or shift registers as long has they can handle reset conditions. To make it easier to use these chips, I'd allow someone to use a reset line. The line can be active low or active high, I don't care.
    There may be a one chip implementation out there, I know that there are *multiple* two chip implementations. In which case the costs are 1.10 at most. A single chip implementation would cost a third of the microcontroller (and not be much bigger) and perform much faster (if speed is a consideration).
    The point here is to have fun trying. I am just looking at the problem more generally, pose the next step to the original question so to speak. Someone may get some benefit out of it (or the results) or atleast enjoy working out a neat simple problem. There are people wasting time on suduko and other puzzles for enjoyment. These types of problems (puzzles) are what I enjoy so I waste my time on them :-)
    -jonathan
  10. #10
    Member level 5
    Points: 2,321, Level: 11
    Join Date
    Nov 2003
    Posts
    88
    Points
    2,321
    Level
    11
    sequential circuit using d- flip flop
    Quote Originally Posted by fm_com_28
    Dear,
    Hi fm_com_28, what you need exactly is nothing but a gray code counter.:D
  11. #11
    Member level 5
    Points: 2,602, Level: 11
    Join Date
    Oct 2004
    Posts
    83
    Points
    2,602
    Level
    11
    fm_com_28
    Quote Originally Posted by beta0
    Dear,
    Also known as a Johnson counter. You can make it with 2 D flipflops (one package, such as 74xx74) and nothing else.
    This reminds me of a funny story. A couple of years ago, an engineer at work showed me the new 5-stage, 10-state counter he had "invented". I said, "Bill, that's a Johnson counter". The funny thing was, his last name is Johnson. Johnson counters have been around for decades.
