+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 32
  1. #1
    Full Member level 1
    Points: 2,594, Level: 11
    Achievements:
    7 years registered
    Join Date
    Feb 2006
    Fayoum, Egypt
    Posts
    99
    Points
    2,594
    Level
    11
    5 to 32 decoder
    Dear,
    I want to construct a 5-to-32 line decoder with four 3-ro-8 line decoders with enable and a 2-to-4 line decoder.
  2. #2
    Advanced Member level 3
    Points: 7,169, Level: 20
    Join Date
    Jan 2006
    Bangalore India
    Posts
    805
    Points
    7,169
    Level
    20
    Blog Entries
    5 32 decoder
    you have 5 input lines and you need output lines
    now let lines are
    d0 lsb
    d1
    d2
    d3
    d4 msb
    connect d3 and d4 to 2-to-4 line decoder
    connect d0, d1, and d2 to all 3-to-8 line decoders.
    Now connect output of 2-to-4 line decoder to enable pins of 3-to-8 line decoders such that the first output makes first 3-to-8 line decoders enable.
    thats it 32 output of 3-to-8 line decoders are your required output
    again try your self and if u need schematic just post in here.
    don't forget to press help me button if this was helpful.
    8 members found this post helpful.
    •   Alt3rd October 2006, 12:14
      advertising
  3. #3
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Feb 2006
    Fayoum, Egypt
    Posts
    99
    Points
    2,594
    Level
    11
    5 to 32 line decoder
    Yes , I need the schematic
    6 members found this post helpful.
  4. #4
    Join Date
    Jan 2006
    Bangalore India
    Posts
    805
    Points
    7,169
    Level
    20
    Blog Entries
    5-32 decoder
    here is the schematic
  5. #5
    Newbie level 2
    Points: 690, Level: 5
    Join Date
    Feb 2009
    Posts
    Points
    690
    Level
    5-to-32 decoder
    my friend if we don't put any inverters is it still right?
  6. #6
    Points: 8,212, Level: 21
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    5*32 decoder
    Quote Originally Posted by nikhilele
    nikhilele, your circuit will not work! ABC lines of bottom 3 ICs are not connected! and last IC has no connection at all !
    Here is the corrected schematic. You can also use inverter (7404) instead of AND gate with last IC. In that case connect D3 to G1 and inverted D4 to G2A.
    EDIT: Ohh I didn't notice this thread is almost 3 year old!! anyways :D
    •   Alt12th February 2009, 18:42
      advertising
  7. #7
    Newbie level 1
    Points: 675, Level: 5
    Join Date
    Mar 2009
    Posts
    Points
    675
    Level
    1 of 32 decoder
    Sir, how will I extend this to make a 10 to 1024 decoder? will using 4 to 16 decoders be feasible?
    1 members found this post helpful.
  8. #8
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    Quote Originally Posted by cerberus_14
    I would suggest use a CPLD or FPGA for it rather than discrete ICs
  9. #9
    Points: 767, Level: 6
    Join Date
    Dec 2008
    Posts
    Points
    767
    Level
    6-to-64 line decoder
    hi cmos! how about a 6 to 64 decoder?? thanks!
    •   Alt22nd March 2009, 15:56
      advertising
  10. #10
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    5 bit decoder
    Quote Originally Posted by hyuugapatik
    Its doable. You'll need 16 of them. But I haven't seen any discrete 6 to 64 decoder IC!
  11. #11
    Newbie level 1
    Points: 627, Level: 5
    Join Date
    Jun 2009
    Posts
    Points
    627
    Level
    2 to 4 decoder to 3 to 8 with enable
    Quote Originally Posted by fm_com_28
    Dear,
  12. #12
    Junior Member level 1
    Points: 1,371, Level: 8
    Join Date
    Sep 2009
    delhi
    Posts
    18
    Points
    1,371
    Level
    8
    5:32 decoder
    pz help me in constructing a 5-32 bit decoder using NAND or NOR gate.
    Plz help
  13. #13
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    6 to 64 line decoder
    Quote Originally Posted by mtechvlsi
    Plz help
    This is how you implement it. Quite easy, isn't it? :D
    2 members found this post helpful.
  14. #14
    Join Date
    Sep 2009
    delhi
    Posts
    18
    Points
    1,371
    Level
    8
    line decoder
    yeah thanks buddy, i was implementing it through using 2-4 and 3-8 decoders.
    i will be needing ur help again if u cud help me in designin 5-32 bit decoder in NOR logic.
  15. #15
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    5-to-32 decoder mosfet
    Thats what I have done.
    Here is the implementation using NOR gates.
    Click "Helped Me" button if you find the replies helpful.
    4 members found this post helpful.
  16. #16
    Join Date
    Sep 2009
    delhi
    Posts
    18
    Points
    1,371
    Level
    8
    32 line decoder
    1st of all thank u, u r rite but i was deployin 4 3-8 decodern n 1 2-4 deocder.
    i wanted to ask again if the ip lines 4m 3-8 decoder at the end of above box r to connected elsewhere also? same in 2nd box?
    •   Alt20th September 2009, 18:25
      advertising
  17. #17
    Join Date
    Jan 2004
    USA
    Posts
    864
    Points
    8,212
    Level
    21
    3 to 8 line decoder
    No they are just the inputs. Not connected anywhere else. E is MSB, A is LSB.
    Since its matrix connection, you only need one 3-8 and one 2-4 decoder.
    Please do not use SMS/Text type language here (ip = input, 4m = from). Its hard to read it.
  18. #18
    Join Date
    Sep 2009
    delhi
    Posts
    18
    Points
    1,371
    Level
    8
    decoder5*32
    My project is CMOS 6T SRAM Implementation in different technology for SNM ,DRV,RM & WM Analysis.
    Frist i have to do READ & WRITE operation means i want to do calculate of Cell Ratio & PULL-UP Ratio. Then I want to do analysis of SNM ,DRV ,WM & RM .So please send me reponse as soon as possible that How will i do this project & also Circuit diagram.I am confused in input & Output of this circuit.plz response me.
  19. #19
    Join Date
    Sep 2009
    delhi
    Posts
    18
    Points
    1,371
    Level
    8
    Tcam
    can any one give me a simple circuit of tcam cell with its prechage ckt and sense amplifier as i need to stimulate one tcam cell.Its very urgent and necessary.Plz give response as soon as possible.
  20. #20
    Newbie level 1
    Points: 553, Level: 5
    Join Date
    Nov 2009
    delhi
    Posts
    Points
    553
    Level
    Re: 5-to-32 line decoder with 3 to 8 line decoder
    sir,
    i want schematic of 5 to 32 line decoder
