nuarizzah
Junior Member level 1
pic 877 serial
can these 2 PIC communicate? if can, how is the pin should be connected because i didn't find any Rx or Tx pin on these two.
i'm going to tun a dc motor controlled by pic16f84A, and i found it does not have a built-in pwm function. can anybody help me with the source code to run this motor? the compiler that i use is picc. thank you
