+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Junior Member level 2
    Points: 1,197, Level: 7
    Join Date
    Sep 2006
    Posts
    23
    Points
    1,197
    Level
    7
    The physical significance of curl of a vector
    Does anybody knows the physical significance of curl of a vector?
  2. #2
    Junior Member level 1
    Points: 1,409, Level: 8
    Join Date
    Sep 2005
    Posts
    17
    Points
    1,409
    Level
    8
    Re: Electromagnetics
    whenever at any point in the space you have changing magnetic field you have curl of the electric field; you get generally non conservative electric potentials; so going a loop in space makes a net change in energy;
    •   Alt27th September 2006, 23:25
      advertising
  3. #3
    Advanced Member level 2
    Points: 7,635, Level: 20
    Mr.Cool's Avatar
    Join Date
    Jun 2001
    Posts
    664
    Points
    7,635
    Level
    20
    The physical significance of the curl of a vector field is the amount of "rotation" or angular momentum of the contents of given region of space.
    h**p://mathworld.wolfram.com/Curl.html
    Mr.Cool
    •   Alt28th September 2006, 01:56
      advertising
  4. #4
    Points: 1,172, Level: 7
    Join Date
    Oct 2006
    Posts
    17
    Points
    1,172
    Level
    7
    Electromagnetics
    curl is a wonderful concept.its what accounts for em wave propagation.imagine a waterpipe closed at one end.now when the liquid flowing in the wire encounters this closed end,it circulates in the pipe this is curl effect.for further details u can always look into feynman's physics book(vol.2 on electromagnetics)
    •   Alt12th November 2006, 17:12
      advertising
  5. #5
    Join Date
    Oct 2006
    Posts
    17
    Points
    1,172
    Level
    7
    just like if the end of a pipe is closed at one end,the water circulates in the pipe this is known as curl
  6. #6
    Mr.Cool's Avatar
    Join Date
    Jun 2001
    Posts
    664
    Points
    7,635
    Level
    20
    Electromagnetics
    nijirazdan i like your analogy.
    here is the kicker.. your analogy makes it very clear that the energy associated with the curl vector (its moving, so must have energy) is entirely contained WITHIN the pipe.. the water can't leak out of the metal pipe after all..
    mathematically speaking, this would be like integrating about the closed path.. where one looks at what is within the border of the integral.
    here is the assumption with this analogy and math:
    that there is NO energy outside the pipe wall, or if you give the benefit of the doubt, there is no "practically usable" energy outside the wall of the pipe.
    what then is the significance of the Heaviside Component?
    food for thought...
  7. #7
    Full Member level 3
    Points: 2,614, Level: 11
    Join Date
    Oct 2004
    Posts
    169
    Points
    2,614
    Level
    11
    The significance of curl is "rotation".if curl is zero then field is conservative.
  8. #8
    Points: 1,053, Level: 7
    Join Date
    Apr 2007
    Posts
    Points
    1,053
    Level
    7
    Quote Originally Posted by suvendu
    Respectfully, rotation can be misleading. The essence of the curl is transverse change. In a 3D vectorial field, if your component in one direction has a variation in the transverse direction, it will induce a curl.
    For example, if your x-component of the vector varies as you move along the y or z direction, it will induce a curl. For the nice water pipe analogy mentioned about, the curl is induced at the boundary of the water flow (the transition from a point with flowing water just inside the pipe to just outside the pipe where there is no flowing water).
  9. #9
    Member level 3
    Points: 1,607, Level: 9
    Join Date
    Aug 2006
    ankara turkey
    Posts
    60
    Points
    1,607
    Level
    9
    it is the maximun net cirulation as the area about the point goes to zero.
    •   Alt27th April 2007, 21:00
      advertising
  10. #10
    Full Member level 5
    Points: 4,127, Level: 15
    neils_arm_strong's Avatar
    Join Date
    Jan 2006
    Posts
    288
    Points
    4,127
    Level
    15
    Electromagnetics
    curl of a vector gives us the value of twice the angular velocity.
