how to convert a spice netlist to a schematic?
estradasphere
Member level 4
hi,
i have a quite complicated and long spice netlist and want to generate a schematic from this netlist in cadence. does anybody know how to do that? thanks.
spicevision!
it is possible you can import netlist using FILE->import in Cadence CIW
I used to do spice netlist to schematic export in EDWinXP ,Cadence tool supports the exporting
I export an cdl of a schematic.then import it,however,it does not work.
some setups are needed?
you can use ADS. however the schematic is not so nice. you can try and see it your self. it only use node name to connect between transistors
I used to import a CDL ,it looks like just as you said.
One should organize the mos transistors by oneself.
hi,
use file-improt-cdl, and you need write a map file to keep the CDL name same with the PDK.
