Does any one have QAM,QPSK,BPSK, etc...Matlab codes
Raghuvij
Newbie level 1
qpsk matlab code
hello,
Hey friends.. I need Matlab code for digital modulation techniques... like ASK, PSK, BPSK, DPSK, QAM, QPSK, etc... If you have that, Please post that...
Advance tnxs to you
bpsk matlab
qpsk n bpsk.....
qpsk with matlab code
see the attached
by the way
there are many others on matlab file center
matlab qam
Did you have Matlab 7.5 version, there are also some default examples for modulation techniques and even IEEE 802.16 d 2004 WiMAX simulink is exist. (go->help->just type qam or qpsk..)
Enjoy!
qpsk matlab
Hi mashhur
not only matlab 7.5 have these examples
the other versions includes many examples
thank you for your reply
bpsk vs qam
Please can I find some source code about ADSL modem I need to have some source code please.
Thanks a lot friends
matlab coding for qpsk
i have attached some matlab tool box
64 qam program in matlab
i need the matlab to generate 64 qam and also to convert 64 qam to 16qam
mat lab code for qam
Hi freind,
you can not convert between them as i know but you can demodulate at 64 and then modulate at 16.
    V
qpsk coding matlab
thanks alot
if you have any thing new in matlab as a simple projects or aplication plese send me at aarrwnas@yahoo.com
spatial multiplexing matlab code
Hi aarr,
I just sent you an invitation, see your yahoo inbox
matlab program for generating qpsk
hi
i want matlab code with comparison of Systems 8-PSK and 8-FSK it is easy my friends?
qpsk project
Hi AYa2002,
thank u for ur reply..
i am doing the project based on repeater...
while i am working,i need the program to convert 16 qam to 4qam...
as u said it can be converted through 16 qam to baseband and then to 4qam..
can u send the matlab code for the above conversation AYA
so that i can continue in my project based on repeater.....
matlab code bpsk
my freind if you know how to do the psk modulation using modem object in matlab and the modulate method. you can see the program that i posted in the following link and you can modify it to your requist.
Thanks
matlab code for qam
any one has a code matlan in QPSK modulation and demodulation? if you have file *.m, that is better....could you send for me via quanghaidv04@yahoo.com
code matlab bpsk
clc;
clear all;
disp('M-Array PSK Modulation')
%create a random digital message
M=input ('M= '); %alphabet size
x=randint(input('Number of binary bit stream = '),1,M);
nsample=40; %oversampling rate.
%use M-PSK modulation to produce y
y=modulate(modem.pskmod(M),x);
%follow with rectangular pulse shaping.
ypulse=rectpulse(y,nsample);
stem(y(1:10),'filled'),grid;
%%transmit signal through an AWGN Channel
ynoisy=awgn(ypulse,input('SNR in dB = '),'measured');
%Create scattet plot from noisy data
scatterplot(ynoisy),grid;
%Downsample at the reciever.
ydownsample=intdump(ynoisy,nsample);
%Demodulate ynoisy to recover the message.
z=demodulate(modem.pskdemod(M),ydownsample);
figure;
subplot(2,1,1);
stem(x(1:10),'filled'),grid;
subplot(2,1,2);
stem(z(1:10),'filled'),grid;
%Check symbole erroe rate.
[num ty]=symerr(x,z)
coding of qam in matlab
Hi Aya,
Do you have Spatial multiplexing matlab code and Space time block coding matlab code? I really need it. I could find some STBC code on google but it's not complete, not working. Please provide me if you have.
Also do you know anything about precoding?
matlab source code for qpsk modulation
I am so sorry my friend, I do not have it
