I can't install Cadence Virtuoso 5.1.4.1
tran
Member level 4
cadence virtuoso windows
Hi all,
I installed Fedora Core 5 on my computer. Then I run file setup.sh of Cadence Virtuoso 5.1.4.1 to install it but I got the following error message
/bin/*.tar : Cannot achieve
So, I don't know whether Virtuoso 5.1.4.1 can install on this platform or not. Please give me the explanation as soon as possible. Because I am in urgent.
Thank you
cadence virtuoso install
Downgrade your tar version to 1.13.25 or early
cadence virtuoso on windows
hi all
i want cadence virtuoso for my project
pls help
cadence virtuoso
Hi Arun.......
U want Cadence....for ur project???What do u mean u want???How can i get frm eda???What actuallu ur expecting???
cadence virtuoso for windows
cadence ic 5141 can work on this platform well!
virtuoso windows cadence
Try RHEL , this platform is better supported by Cadence
install cadence 5.1.4.1 fedora
Use CETOS (a free clone of REDHAT EL), I installed Cadence without any kind of problem
how to install cadence ic 5.1.4.1
Maybe, you ought check your medium, whether they is for linux?
virtuoso cadence on linux
try to use RHEL TO INSTALL IC5141..
free cadence virtuose tools in linux
Do it with Redhat Linux 7.2
cadence virtuoso установка
use ubuntu
cadence ic 5.1.4.1
try to use windows version simulators, they are good too and easy to install. not necessary to install linux things for personal use, not worth.
cadence virtuso for windows
Mandriva works well for cadence
installare cadence virtuoso
I've installed Mandriva 2009 and the OS is working well...but when i'm trying to install the Virtuoso, after executing the SETUP.SH it asks me for the path...after providing the path, it does make the folder but it stops installing saying, you do not have the permissions to install the software and you require atleast 10MB to install the software...
i've validated both, i''m logging in with root using "su -", and i do have enough free gb's but still it fails...looking forward for an early solutions.
Best Regards
Jamshid Dastur
