Mentor Calibre DRC error: cell DLY2D16 is referenced but not defined
elektor
Member level 3
I use GDSII file from Silicon Ensemble..
When I've imported this file to Calibre DRC ( with "rule file" - I've checked this file -- it's ok ) and run DRC, I've obtained error :
"Cell DLY2D16 is referenced but not defined"
Where is mistake ??
Any sugestion ?
Regards
Elektor
Re: Mentor Calibre DRC
Where is mistake ??
Any sugestion ?
Regards
Elektor
you need to merge the standard cell gds & IO cells gds
Re : Mentor Calibre DRC
How ?? In Silicon Ensemble or in Calibre DRC ??
What variables I must set up ???
Regards
Elektor
Maybe you can use a layout editor, such as C@dence's Virtuoso or Nov@s' L@ker.
I don't think SE or C@libre can do a gds merge....
Probably you first have to "flatten" your layout design hierarchy before you produce the GDSII .This can be done in any layout editor
I think when you streamOut cell refence your lib
mistek the cell DLY2D16 just have boundary
no real layout
suggest you from your streamOut cell check
Alcohol
