A.Anand Srinivasan
Advanced Member level 5
we tried a full wave rectifier using a bridge circuit and we the circuit works well when i use a transformer as input but doesn't work when i use a function generator as input... why?
Make sure the function generator has enough output current to drive the load.A.Anand Srinivasan said:we tried a full wave rectifier using a bridge circuit and we the circuit works well when i use a transformer as input but doesn't work when i use a function generator as input... why?
First of all: set up the scope for a differential measurement and use two channels with two probes. Don't connect the probe grounds to any active circuitry or floating grounds. This will prevent the problem that unkarc pointed out and it may very well solve your problem.A.Anand Srinivasan said:... actually i got a halfwave rectified wave as output if i used a function generator...
