difference between digital signal and discrete time signal
sarkararghya
Newbie level 6
difference between discrete and digital
what is the difference between digital signal and discrete time signal?
i am not sure but i think digital signal is discrete in time and can have any of some finite number of specific values , while the discrete time signal is only discrete in time but can have any value just like analog signal
Re: difference between digital signal and discrete time sign
A discrete signal or discrete-time signal is a time series, perhaps a signal that has been sampled from a continuous-time signal. Unlike a continuous-time signal, a discrete-time signal is not a function of a continuous-time argument, but is a sequence of quantities, that is, a function over a domain of discrete integers. Each value in the sequence is called a sample.
When a discrete-time signal is a sequence corresponding to uniformly spaced times, it has an associated sampling rate; the sampling rate is not apparent in the data sequence, so may be associated as a separate data item.
[edit]
Digital signals
A digital signal is a discrete-time signal that takes on only a discrete set of values. It typically derives from a discrete signal that has been quantized.
Common practical digital signals are represented as 8-bit (256 levels), 16-bit (65,536 levels), 32-bit (4.3 billion levels), and so on, though any number of quantization levels is possible, not just powers of two.
discrete signal is discrete in time but continuous in amplitude..
digital signal is discrete in both time and amplitude.
:wink:very nice...
helpfull...
