Will this code clear the memory block in the flash memory?
london
Member level 4
following program i wrote
while(FCTL3 & BUSY);
FCTL2 = FWKEY + FSSEL1 + FN0; // SMCLK/2 = ~500kHz
FCTL3 = FWKEY; // Clear LOCK
FCTL1 = FWKEY + ERASE; // Enable segment erase
*(unsigned int *)0x1000 = 0; // Dummy write, erase info B
FCTL1 = FWKEY + WRT; // Enable write
Lock_f=Lock;
FCTL1 = FWKEY; // Done. Clear WRT
FCTL3 = FWKEY + LOCK;
conform me when prog execute the bolded line will be clear the memoey block or only the 0x1000 memory segment in the flash memory?
flash memory
It will clear when your program has execute that line.
that is thw value of 0x1000 is 0;
the function of your line same as below
int *p;
p= (unsigned int*)0x1000;
*p=0;
by
arsamy
    london
