how to use output of c program in my vhdl program
subramanyam
Member level 3
bengaluru
hii,
I am doing a project on memory controller in which i am trying to implement a design using fifos and FSMs . this design acts as an interface between the fast peripherals sending burst of data , and a slow memory.
i have implemented the design in VHDL. whenever the external device request read into memory, my design will put the address on the address bus of memory and, for write data it put the address on address bus and data on data bus .
my problem is, i want to implement the memory using linked lists in C language.
so whenever it takes that address and data how can i receive them into my vhdl testing program.
And how can i link these two, plz any one help me regarding this.
thank you,
subbu
(1) you can generate the data you want by C programming and then put them into you Testbench as TestVector
(2) If you're using unix, you can use script such as perl to link the two application by invoking system call.
using c program output into a file and you can read in vhdl usign file is in command .. thats easy way and generally we follow this way in industry..
Regards
Shankar
subramanyam said:
hii,
thank you,
subbu
Export your C output into one file. Call this file in VHDL code. Make this process automatic so it will do it countinuously. This is the standard way in simulation. Normally such method is used in Testbench for system level simulation.
for that you have to use following libraries:
USE IEEE.std_logic_textio.all;
USE std.textio.all;
and readline command in vhdl
there is a concept of FLI(Foriegn language interface) to link C model and vhdl model.
hys said:
Have a look at the following URL.... that may help u in using FLI.
h**p://www.lispworks.com/documentation/lwl42/FLI-U/html/fli.htm
Best Regards,
Harish
h**p://hdlplanet.tripod.com
h**p://groups.yahoo.com/group/hdlplanet
the FLI refered in link is related to LISP not VHDL. VHDL FLI is different...
It is part of VHDL standard and supported by vhdl simulators (or that support mix sim).
A quote from ModelSim® SE Foreign Language Interface
V e r s io n 6 . 1 e Pu b l i s h e d : M a r c h 2 0 0 6
FLI routines are C programming language functions that provide procedural access to
information within the HDL simulator. A user-written application can use these
functions to traverse the hierarchy of an HDL design, get information about and set the
values of VHDL objects in the design, get information about a simulation, and control (to
some extent) a simulation run. The header file mti.h externs all of the FLI functions and
types that can be used by an FLI application.
