Need C program for counting down on 7 segment display
asham
Junior Member level 1
i need a c program that counts from 9 to 0 on the 7 segment display..i'm using mplab ide and p18f4520.. i have created such programs using assembly language but i in c language,i don know much....any help would be appreciated...
p18f4520 7 segment display program
here is c code written in mikroc pic compiler.
// microcontroller : PIC16F84A
// Project: 7seg_display1
// This project is designed to work with PIC16F84A;
// with minor adjustments, it should work with any other PIC MCU.
// This code demonstrates how to display number on one 7-segment display
// (common cathode).
// Display is connected to portb(RB0..RB7, segment A to RB0,
// segment B to RB1, etc); common cathode is connected to the pin RA1 on porta.
// Number is incremented every 1 second
unsigned short i;
// Function returns mask of num for common cathode 7seg. display
unsigned short Mask_7seg(unsigned short num) {
  switch (num) {
    case 0: return 0x3F;
    case 1: return 0x06;
    case 2: return 0x5B;
    case 3: return 0x4F;
    case 4: return 0x66;
    case 5: return 0x6D;
    case 6: return 0x7D;
    case 7: return 0x07;
    case 8: return 0x7F;
    case 9: return 0x6F;
void main() {
  INTCON = 0;  // Disable PEIE, INTE, RBIE, T0IE
  TRISA  = 0;
  TRISB  = 0;
  PORTB  = 0;
  PORTA  = 2;
  // Main loop
  do {
    for (i = 0; i <= 9u; i++) {
      PORTB = Mask_7seg(i);  // Display digit on 7seg display
      Delay_ms(1000);        // 1 second pause
  } while (1);
Re: 7 segment display
thanks veri much..i''ll try it out
